301 SAXON .
Re: 301 SAXON .
Postby davegsm82 » Sat Aug 02, 2014 5:05 am
No problem, sounds like you have the 'PVL' ignition unit coupled with the combined regulator/rectifier unit, earlier models had the reg/rec under the seat.
Sounds like you're on your way to having it sorted anyway :)
Good luck, Dave.
davegsm82
Re: 301 SAXON .
Postby howard64180 » Mon Aug 04, 2014 4:28 am
I was looking for information on timing a Saxon 301 and found this:
http://www.mz-b.info/ifo/etz-igni/etszifo.htm
howard64180
Re: 301 SAXON .
Postby howard64180 » Sun Aug 17, 2014 6:56 am
With reference to the above timing method, i just tried it and it didn't work. I was getting no voltage at the yellow/black wire and at first thought my unit was fried. I did, however get a good spark at the plug so timed it by looking for the spark.
howard64180
Previous
Users browsing this forum: Bing [Bot] and 6 guests
