New member from Cumbria, UK
Postby howard64180 » Mon Aug 04, 2014 4:25 am
Hi, after a long break from MZs I am currently resurrecting a Saxon Tour 301. It appears to have been thrown together with parts from whatever was at hand. The only part I hadn't stripped was the forks and I soon found out what a mistake that was. The 'clonking' noise later discovered was found to be springs differing in length by 3/4 inch. The crank was ruined (spun clutch), clutch centre ruined, most nuts in the engine were loose (hence ruined 68 tooth gear wheel), silencer falling apart internally, oil pump had a broken shaft (apparently, an attempt had been made to glue it back on), etc, etc. Shares in Ost2rad must be doing very well!
Anyway, after browsing on here for a while I find I have answers to some of the technical questions so thought it was time to join.
howard64180
Re: New member from Cumbria, UK
Postby phoenix76rb » Mon Aug 04, 2014 8:51 am
Welcome aboard; sounds like you brought your bike back from the dead!!!! Congrats.
Tim in Herndon, VA, USA
1995 MZ-660 Skorpion Sport
1967 Honda CL-90
2000 Harley FXDX
2007 Harley FLHXI
phoenix76rb
Postby Tony the Skin » Tue Aug 05, 2014 2:41 am
Welcome from sunny Lancashire. Sounds like the bike should be called Lazarus :wink: . Good luck with it. The 301 Saxon is a pleasure to ride.
Tony the Skin
Users browsing this forum: No registered users and 212 guests
