where iz the oil ?
where iz the oil ?
Postby MichaelTorre » Sat Jul 05, 2014 2:16 am
Hello.
I have 1974,TS250, 4 speed.
Filling the gear box book states fill with 750cc of gl4.
OK
That's 25.36 oz, liquid.
ok.........
I put in 35 oz, and I have the drain screw out, 4:00 o'clock
position, in relation to the clutch adjust cover.
Peeking in............ wherz the oil???
M-
MichaelTorre
Re: where iz the oil ?
Postby den » Sat Jul 05, 2014 1:39 pm
if you put it in ,its there, as the book says , two stroke gearbox oil i think is designed to foam up and expand when the engine is running thus coating all moving parts,,whats bill say on the matter,,Bill! :?:
den
Postby MichaelTorre » Thu Jul 10, 2014 1:49 am
as some say.
Right.
I left the overflow plug out for 24 hours and I was rewarded to see and overflow in the drain pan.
Apparently it takes a long time to trickle from the gearbox to the clutch housing where the level
screw is located.
Interesting.
is that normal?
M-
MichaelTorre
Postby therealche » Thu Jul 10, 2014 6:38 am
I'm not sure why but I know I have topped up the gearbox, nothing comes out, put in another 50ml, nothing comes out, put another 50ml in and 100ml comes out! It's the MZ way
therealche
Users browsing this forum: No registered users and 176 guests
