ETZ 125 Frame Number
Postby wrigley-etz125 » Mon Jun 30, 2014 10:22 am
Hi all,
recently purchased said model without a log book or form, been off the road for 10 years. Does anyone know where the VIN number is located? The only codes I've found are two 10-digit codes begining YID, and 7 digit code.
Much appreciated.
wrigley-etz125
Re: ETZ 125 Frame Number
Postby arry_b » Tue Jul 01, 2014 2:03 am
The frame number is stamped into the headstock on an ETZ125, and should also be on an aluminium plate riveted to the headstock.
You'll find no VIN in the format that you'd find on a newer vehicle because there isn't one.
arry_b
Postby wrigley-etz125 » Mon Jul 07, 2014 6:00 am
thanks i've found it now, it was in vin format aswell.
wrigley-etz125
Postby DAVID THOMPSON » Mon Jul 07, 2014 9:58 am
where was it located so others looking can find it
and what year
numbers seem to be in different places.. on different years and models
i saw a 2 smoker at vintage days in ohio usa one year
and it was on a tab on the frame at the rear below where your back pocket would be when seated
never did figure out what year it was
Return to 125 cc
