more mix and match
more mix and match
Postby vicar » Fri Jun 20, 2014 1:28 pm
[/attachment]
I bought some TS I think gauges for my Kanuni ETZ it already had earlier gauges fitted but because of my charging system the electronic rev-counter couldn't be used. but I wanted to keep the later ignition switch and steering lock a big hole was drilled I will sort out the cosmetics when the weathers to nasty for riding,,,,,,,,,,,,,,,,,,
vicar
Re: more mix and match
Postby therealche » Tue Jun 24, 2014 5:32 am
True Z-Cred!
therealche
Postby vicar » Tue Jun 24, 2014 10:35 am
Oh forgot to mention the value of my bike has rocketed it is now a low mileage bike after the clock swap.........And what do you think of the AC Cobra stripes on the tank 2 strips of insulation tape an a bit of window tinting film, again an expensive mod .....................Road tires fitted cos the enduros didnt like corners. I now have a golden boy Korean on the back and a Cheng Shin on the front Both part worn £17 the pair inc postage from flea bay This was extortionate but if you want the best it costs. I am achieving my plan of a multi national bike...
vicar
Postby phoenix76rb » Wed Jun 25, 2014 6:08 am
Very nice! Hope the Michelin Tire Guy is not too put out by your street tire selection!
Tim in Herndon, VA, USA
1995 MZ-660 Skorpion Sport
1967 Honda CL-90
2000 Harley FXDX
2007 Harley FLHXI
phoenix76rb
Postby vicar » Thu Aug 07, 2014 11:07 am
The exhaust on my bike was home made it had plenty of volume but no tapers and a lot of bends.and it wouldn't rev out
After digging about a bit I found an other exhaust in the pile of junk I call my shed.volume wise it is similar to a std exhaust but the baffling silencer bit at the end of the exhaust is a lot less restrictive .
I have taken it for a test ride and its ok, the bike buzzes up to 70mph in fourth no problem. its a work in progress got to decide if its side panels or not ,and I will keep you updated and like all my mix n match its all free bits......
vicar
Postby DAVID THOMPSON » Thu Aug 07, 2014 12:25 pm
watch the heat that exhaust may get you a holy piston
piston tops take a beating if things are not correct
