Srinath wrote:So would it be better to run it on 87 octane ?
That means I should stay with 10:1 or under compression ?
I found a lovely cast piston (which I wholly prefer over forged) in 102. Whooo hooo ...
Thanks.
Srinath.
Srinath wrote:How can there be valve seal blow by, the valves supposed to be open when its sucking, and supposed to be closed when compression ...
Can it squeeze past the seated valve ?
