help gas tank won't fit
Postby credit » Mon May 09, 2005 3:31 pm
I need help after east coast atv modified the bike and added the new carbs they had to shim the gas tank to get the carbs in. now tha plastic won't line up .......................any sugestions
credit
Postby DEmark » Mon May 09, 2005 7:57 pm
What kind of carbs did they install? What part of the carbs interferes with the tank? Is it the throttle linkage? I just installed a set of 35x35mm Keihin FCR's on my Baghira, it was a real tight fit, but I was able to get the gastank on after modifying the throttle bracket. I also had to modify the coolant ell on the right side, and the 10mm oil tube sticking out off the frame. I've put 2000 miles on it, it works....
DEmark
Postby credit » Mon May 09, 2005 9:17 pm
one flat side carbs FCR 35mm I believe one Klien carbs
credit
Postby credit » Tue May 10, 2005 6:45 pm
demark what type of battery are you using and where did you get it
credit
Users browsing this forum: No registered users and 173 guests
