95SaxonTour wrote:Just trying to get a consensus here. I tried lubing up with grease before
(think I used wheel bearing grease) and it wound up slung all over the
front and rear covers. Since then, Ive switched off to just peeling back
the boots and hosing it down with chain lube. Is this okay? I dont see
why it wouldn't be. But if there is an easier way, Id like to know.
Ryan
comanche91 wrote:I use lithium grease liberally as recommended in the MZ manual and the Rotax manual. Lucas Red in my case.
Spitfiregoggles wrote:Well communist bikes SHOULD use red grease..........stands to reason doesn't it?!
95SaxonTour wrote:As I was looking, I see that the chain in the pictures has a clip type master link (as does the chain that I have now) Is it advised to use a rivet type on this bike?
Users browsing this forum: Bing [Bot] and 8 guests
