Etz lights/key position
Postby Lpo90 » Thu Nov 28, 2013 3:17 pm
Hi, if I turn to 7 o'clock position whilst in the ignition only the back light comes on not the front, is this right or should the front light come on also. Front only comes on at 8 o'clock position.
Lpo90
Re: Etz lights/key position
Postby arry_b » Thu Nov 28, 2013 4:36 pm
Pilot light should come on.
arry_b
Postby Lpo90 » Fri Nov 29, 2013 10:47 am
ThAnk for fast reply, I don't seem to have the original headlight on mine the bulb is in a fixed unit, and only 1 bulb inside
Lpo90
Postby therealche » Fri Nov 29, 2013 4:37 pm
No, someone has stuck a sealed beam unit in.
therealche
Postby arry_b » Fri Nov 29, 2013 6:36 pm
That unit's from an old Mini.
You can get a connector that has a pilot bulb in it which dangles underneath the connectors and shines through teh round window you see under the pins. Here's one: http://www.somerfordmini.co.uk/eshop/in ... ts_id=4821
Although it's probably best to replace the sealed beam with a good second hand light unit if you can find one.
arry_b
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
