ptong wrote:I have an RT 125 same engine different setup. There are aftermarket exhausts by Supertrapp on their website, and I am sure you can get a sprocket from an MZ dealer online too. They also have 150 kits, and other items. I would recommend having a look at the 125 posts for cam timing... this is a kit you can get also that was apparently developed by a dude in California who races the SM's.
anyway hope that maybe helps. I don't have the addresses on hand as I am switching to a new computer.
micheleen wrote:For exhaust and rear sprockets try Ksports
jbthumper wrote:witttom,IMHO,when getting a supertrapp,make sure you're ready for the morning rumble...could be too loud for some....
check-out powroll.com too...
jbthumper wrote:check-out powroll.com too...
DAVID THOMPSON wrote:hello tom
i have a rt125
and the only issue i have is be careful about doing something
that stalls the motor i have broken the starter freewheel
twice on mine
do a search on freewheel or starter clutch in the search menu on this site
this part i recomend for your personal spairs
it will be 2 weeks friday since i ordered one
the part numbers on request
my total down time in 3 years because of this part is approching 50 days
3rd one to be installed as soon as it gets here
bdalameda wrote:As to the Freewheel. I had experienced two freewheel failures previously. After looking at the e-start mechanism I discovered that the reducer gear has a slip type clutch in it that is kept in tension by a wave washer. This is designed to give the system some slip to prevent the freewheel from being over torqued. I took apart the slip clutch and noticed that the two mating surfaces of the clutch were gouged. This was preventing the clutch from slipping and kept the starter drive system directly coupled to the motor when the freewheel clutch was engaged. I polished the mating surfaces and relieved some of the tension on the wave washer which allows the slip clutch to slip easier. I haven't had a problem since even with the 150 kit installed, it has been over a year now. The only difference I notice is that the slip cluch slips slightly when the engine is cold and I engage the starter. This doesn't prevent the engine from starting but it definitely protects the freewheel from being damaged.
Users browsing this forum: No registered users and 135 guests
