motor starts then dies.....
Postby jacquesvins » Sat Oct 26, 2013 12:47 pm
Had my 125 TS starting, running for a minute or so and then dying with no chance of a restart....
Only if plug removed, spark checked, plug dipped in petrol does it sometimes start, but then dies again - so frustrating....
Does anyone know what could be the cause, any ideas would be most welcome,
Cheers
Jacques.
jacquesvins
Re: motor starts then dies.....
Postby therealche » Sat Oct 26, 2013 2:49 pm
First thing to check is that the hole in the petrol cap isn't blocked. If it is you get a partial vacuum in the tank which stops the bike. Then while you are trying to work out why air bleeds in and off you go again
Also try a new plug... always seems to work wonders on an MZ
therealche
Postby jacquesvins » Thu Oct 31, 2013 3:20 pm
Wow you really know your stuff..... yes the little breather hole was blocked and made the fuel run down to the carb just too slowly...... the plug was a new one, so I knew it was not that - thanks so much for your brilliant advice...... I was just about to give up...... cheers, Jacques.
jacquesvins
Postby therealche » Thu Oct 31, 2013 4:08 pm
Glad to be of help!
therealche
Return to 125 cc
Users browsing this forum: No registered users and 217 guests
