Is it my clutch plates? TS 125 1987 clutch slipping
Postby jacquesvins » Fri Oct 04, 2013 12:14 pm
Hi, my MZ TS 125 is now running but the clutch appears to be slipping even though the adjustments on the cable and lever have been made - would the best option be to replace the clutch plates or is there something I could try first ?
Please let me know - cheers Jacques 07553485183
jacquesvins
Re: Is it my clutch plates? TS 125 1987 clutch slipping
Postby therealche » Fri Oct 04, 2013 3:56 pm
Steady on there. we don't want people throwing money around willy nilly. When you get your clutch apart you want to measure the thickness of the friction plates. Anything over 3.1mm is fine. The springs should be 49mm long. Quite possible its just the plates that are glazed. Rub the plain plates with some wet and dry. Soak the friction plates in petrol for a couple of hours ( or overnight) giving an occasional scrub with a tooth brush. Allow to dry then give a light rub over with some coarse wet and dry ( not to much , you don't want to remove too much material. Reassemble , new oil and see how you go.
therealche
Postby therealche » Fri Oct 04, 2013 3:57 pm
Oh and make sure your clutch cable is well lubricated, and routed so as to move freely
therealche
Postby jacquesvins » Sat Oct 05, 2013 2:34 pm
Thanks so much for the fine advice.... I shall duly try as suggested, cheers Jacques.
jacquesvins
Postby jacquesvins » Tue Oct 15, 2013 2:06 pm
therealche wrote:Steady on there. we don't want people throwing money around willy nilly. When you get your clutch apart you want to measure the thickness of the friction plates. Anything over 3.1mm is fine. The springs should be 49mm long. Quite possible its just the plates that are glazed. Rub the plain plates with some wet and dry. Soak the friction plates in petrol for a couple of hours ( or overnight) giving an occasional scrub with a tooth brush. Allow to dry then give a light rub over with some coarse wet and dry ( not to much , you don't want to remove too much material. Reassemble , new oil and see how you go.
Thank you so much for the fantastic advice..... all went to plan and yes the clutch is fully operational again - all the measurements were well in spec, but the plates etc were very dirty, plus the bike had stood for many years.
So I am most grateful for the help and the cost saving too - wonderful...... cheers Jacquesvins
jacquesvins
Postby therealche » Tue Oct 15, 2013 3:22 pm
Glad to be of help!
therealche
Return to 125 cc
Users browsing this forum: Bing [Bot] and 228 guests
