Srinath wrote:Chain lube ?
That crap usually gets everywhere.
Cool.
Srinath.
philtrophysport wrote:My trophy sport does exactly the same,and in the same place,the only place I;ve narrowed it down to is the base gasket which I'm aiming to change when I get a spare weekend,although it doesn't always leak badly it seems messier when I give the bike some welly!...when its ridden sedately theres hardly any oil visible.
philtrophysport wrote:Let us know if it makes a difference if you get round to changing the gasket before I do mine,it should also improve compression and maybe give the bikes a bit more oomph!
philtrophysport wrote:Absolutely...the gasket i'm talking about is the cylinder base gasket found between the bottom of the finned barrel and the crankcase,a relatively simple removal of cylinder head and barrel and application of a new gasket and some Hylomar blue or similar compound should sort it...
Users browsing this forum: Bing [Bot] and 15 guests
