Oil change procedure
Postby Bill » Mon Jul 18, 2005 11:32 am
Does anyone know what the procedure for changing the oil on one of the Rotax engined bikes is?
Bill
ROTAX OIL CHANGE
Postby DAVID THOMPSON » Tue Jul 19, 2005 12:30 am
HAD MINE A YEAR AND A HALF THIS WAS FUN THE FIRST TIME :smt040
Oil change rotax motor
Take a siphon hose and remove all the oil from the Main tank in the frame by way of the dipstick hole
This reduces the amount you will spill later… :-D
The oil filter is K&N 151 same as BMW f650
It is located on the right side behind the plastic Cover over the front chain sprocket
It is a lot of fun to remove …Once you have the chain cover off it will be
Easy to find the filter cover
The oil drains are 36 and 37 in the picture and are on the
Right side of the bike on the oil pan… MAKE SURE you clean the magnetic plug 37
I only remove the oil pan every other oil change
If the engine history is unknown Do IT
You will not get much out of lower end…The oil is in the frame tube tank
The lower case fill plug is on the left about 4 inches behind the
Clutch cable where it enters the left case (move the kicker it blocks the view) 8mm Allen I think
When refilling about ½ quart goes in here
To completely drain the Frame oil tank you must remove
The large bolt that is on the hose to the engine at the rear
Of the frame backbone
This is the reason to siphon the tank … so the mess is not as big
This engine is the biggest mess to change oil in of any bike I have ever worked on
its not hard to do the oil change …but wait till you start the mess cleanup
One half quart in lower case 2quarts in frame back bone
run engine and top up as needed
3 qt should do it
DO CHECK EVERY THING BEFORE STARTING MOTOR
This is a good time to check the chain before putting the cover back
Here is a warning about the Saxon /etz type frame
The nut on the right seems to holds the sprocket carrier on the right Side of the swing arm and is torqued down separately
From the axle on the other side
You must line up the wheel and use the torque wrench on
Both the axle and the nut
I have not had mine completely apart and will update this ASAP
When working on mine it seemed the axle and the nut on the other side were in some way not quite connected
Or were separate from each other until tight
Torque value unknown but probably at LEAST 50 ft pounds a rt125 is listed as 100nm
OIL I USE IS SHELL ROTELLA T 15W-40
JULY 18 2005
see pictures in this post
IF YOU SEE A MISTAKE EMAIL ME ASAP
this is based on a 1995 504E motor
CLICK ON THE BELOW PICTURES TO SEE A FULL VIEW
ROTAXOILCHANGE rotaxoilchange
picture of drain and fill locations
rotax oil bike change pict.jpg (29.74 KiB) Viewed 10415 times
oil change ref....
rotax oil change 1.JPG (233.85 KiB) Viewed 10436 times
Last edited by DAVID THOMPSON on Fri May 18, 2007 11:20 am, edited 2 times in total.
Thanks Dave!
Postby Bill » Tue Jul 19, 2005 7:33 am
Wow, that really is complex. Oh well, everything that's fun comes with a price.
Bill
RE: Rotax Oil Change
Postby Nozz » Wed Jul 20, 2005 5:35 pm
Hi Bill and welcome. Dave was asking for everybody with Rotax 500 MZs to "stand up and be counted". As far as I know, not too many responded. Please upload a picture of your bike when you get a chance...
Thanks again to Dave for the truly helpful info on the maintenance issues..
Nozz
Re: Oil change procedure
Postby roloscotusa » Fri Sep 06, 2013 11:16 pm
Thanks for the post. I just changed the oil on my MZ500 Country. I had to replace all the sump gasket and drain plugs because the previous owner had messed them up. I got the Rotax spares from American Dirt Bike and the MZ Spares from the MZ shop in the UK.
I checked the oil after 2 quarts in the frame tank and its still below minimum level. I put 0.5 Quart in the engine case. Any thoughts before I start it up. Stick some more oil in?
By the way, I forgot to siphon the frame tank and got oil all over the place. What a disaster.
Mark.
roloscotusa
Postby DAVID THOMPSON » Sat Sep 07, 2013 6:37 am
check it warm
and if your dip stick is missing off the cap behind the steering head there is a post
on here about its size
viewtopic.php?f=26&t=6299&hilit=dipstick
and there is a hose from top of tank in frame to top of motor
do check it this winter to see if it is healthy
and not rubbing the tank anywhere
its a bitch to change on a road trip and a big mess
Postby ralf » Thu Apr 06, 2017 2:44 am
Really helpful post. My dipstick rod is missing, must be a common problem. Followed the link and now know the length the rod should be but is the level checked with the dipstick screwed in or not.
I just picked up a 500R which has been dormant for several years and is in need of lots of TLC.
Help appreciated.
Neil.
Skorpion, RT125 and now a 500R.
ralf
Postby Ryanakers+mz500r » Tue Feb 25, 2020 5:09 am
Really glad i found this post thanks for the detailed and thorough explanation
Ryanakers+mz500r
Users browsing this forum: Google [Bot] and 6 guests
