mz saxon sportstar 125cc restricted?
Postby branshano666 » Mon Aug 26, 2013 5:47 am
Hi there I have recently purchased an mz saxon soortstar 125cc 1997 at the moment it is only capable of 65mph with 3000 rpm to spare the bike wont push any more and 65 is the speed down a hill I only hit 60 maybe 61 on a straight any advice on how to derestric if possible would be appreciated
branshano666
Re: mz saxon sportstar 125cc restricted?
Postby DAVID THOMPSON » Mon Aug 26, 2013 6:37 am
try cleaning the crud out of the exhaust pipe and check the timing and a clean air filter
and with my limited 125 cc 2 cycle use your going good
speed at 55
the ones i had were harley hummers 165 cc.
50 mph with someone towing you home
was fast
my 4 cycle rt125 with 20,200 miles on it
is geared 15x52 and redlines at 69 mph
it runs good at 55 mph to 60 above 60 its just working too hard to make me happy
This is why people like bikes 350cc or bigger.
you do not have to ring it's neck to go somewhere at a reasonable speed
the size restrictions on bike displacement has created an inflated need for 125cc bikes
in europe
Postby arry_b » Mon Aug 26, 2013 7:03 am
branshano666 wrote:Hi there I have recently purchased an mz saxon soortstar 125cc 1997 at the moment it is only capable of 65mph with 3000 rpm to spare the bike wont push any more and 65 is the speed down a hill I only hit 60 maybe 61 on a straight any advice on how to derestric if possible would be appreciated
That's about all you're going to get out of it. Forget any thoughts of derestricting it as it's not restricted, but you'll not get any more performance unless you spend more than the bike's worth. The ETZ125 motor will pull around 7000 rpm, no more. You'll never see the tacho all the way over to the right, the engine isn't designed to do that. Design top speed is 100kmh (63 mph) on the flat.
Don't forget that the speedos on small Japanese bikes tell massive lies - a "mate on a YBR125" isn't really going any faster than you are, even if his speedo says 75.
Depending on your weight, you may be able to get it up to 65 on the flat if you tuck down behind the nose fairing. New plug, new air filter, check the timing, cleaning out and setting up the carb properly will get the most out of the engine. Decoking the exhaust pipe may help - a "sports" pipe definately won't.
If you've passed your test, an ETZ150 top end (try ebay.de), bolts straight on.
However - the best way of going fast on an ETZ or Sportstar 125 is to buy the best tyres you can afford (try a Michelin Pilot Sporty on the front), change the fork oil, service the brakes and learn how to take corners quickly without dropping much speed. There's not much that'll keep up with a well sorted MZ around the twisties.
arry_b
Postby branshano666 » Mon Aug 26, 2013 7:17 am
Thanks for your quick reply very informative I am yet to check the air filter and exhaust changed spark plug so ill go with that as for the 150 top end im waiting to take my test at the moment and in all honesty ill probably be getting a 400 to start with thanks guys
branshano666
Postby DAVID THOMPSON » Mon Aug 26, 2013 2:43 pm
my 4 stroke 125 works great for me
but i live in an area with very curvy roads and really low speed limits
the common joke here is that every where you go is up a steep hill never down
there is maybe 20 miles of road posted over 55mph
within 40 miles of my house
then someone passes you like your setting still in one of these trucks
Return to 125 cc
Users browsing this forum: Bing [Bot] and 228 guests
