Front brake lever
Front brake lever
Postby duncmac » Tue Aug 20, 2013 8:38 am
Got the MZ out for the first time in a month or two.
Managed to push it off the side stand, strapping a bag to the back.
Snapped off the front lever. Anyone know what else uses the same master cylinder/lever? Or where to get a brake lever from?
Also when on the side stand its barely lent over, I have to be very carefull when I park it up. What do yours do? lean over quite a bit or just barely?
Might be the wrong side stand, think I remember reading that the enduro side stands were longer, there might be one on mine. Mines 34cm long tip to tip.
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Re: Front brake lever
Postby DAVID THOMPSON » Tue Aug 20, 2013 12:03 pm
grahams for the lever
i live in the usa i sorted through a collection of over 3,000 levers at an old dealership
about 5 years ago and did not find a match
if any one knows what does fit doooo post it
but it will be something not sold in the usa
my traveller ,saxon tour 500cc and the rt125 4stroke all use it
replacement levers has been a major expense here because of the shipping cost
and the levers are not cheap
Postby duncmac » Tue Aug 20, 2013 12:30 pm
I've had a punt on this
Front Brake Lever Black KTM60,KTM65SX (460-13-002-000)
http://www.ebay.co.uk/itm/130656815951? ... 1423.l2649
Its cheap and I fancied my chances, I'll let you know how it turns out. Otherwise the one from grahams looks to be around £24
In the meantime I'll use the short two finger brake I made this morning :smt005
Edit this also looks promising
http://www.racing-planet.co.uk/brake-le ... hOoFFPgK2w
duncmac
Postby MZ in Oz » Tue Aug 20, 2013 2:46 pm
I have just ordered 2 levers myself from this site.
SELLER.
TRIUMPH-MZ-MOTORCYCLE-HEAVEN-PARTS
MZ in Oz
Postby DAVID THOMPSON » Tue Aug 20, 2013 3:26 pm
SELLER.
this adv is kevin salt north of london just a bit east of luton
he is a breaker parts dealer for all kinds of bikes
Postby duncmac » Wed Aug 21, 2013 5:13 am
The ones TRIUMPH-MZ-MOTORCYCLE-HEAVEN-PARTS has on ebay for MZ look like a good fit.
I'll see what the one I ordered is like and report back.
Pretty sure this one is on the money
http://www.splatshop.co.uk/domino-f-brake-blade-grimeca.html
Domino Front Brake Lever Blade for use in Grimeca master cylinders.
Pivot Hole Inner Dia: 8.1mm
Washer Recess: 15mm
Centre Pivot to Centre Plunger: ≈ 19mm
If it does fit, would save a few quid over the "originals"
Surprised that alternative supplier brake levers isnt already a "known" thing.
This also looks on the money
http://www.domino-group.com/en/catalogue/levers_Detail.aspx?idmaster=2351
duncmac
Postby DAVID THOMPSON » Wed Aug 21, 2013 8:58 am
LEVERS
i have been looking since 2003 and have never found an other bike they fit except MZ
and the rear sprockets on the 125 4 strokes are also rare
if you do find them on another brand ...that bike was probably not sold in the usa
Postby duncmac » Wed Aug 21, 2013 3:23 pm
So the ebay one for the KTM was a bust, I'll have one last punt on that domino lever and then admit defeat.
duncmac
Postby den » Thu Aug 22, 2013 1:41 pm
thought the 125 one was the same
den
Postby duncmac » Thu Aug 22, 2013 1:53 pm
Still 25 odd quid though.
If this domino one fits then thats a lot cheaper.
duncmac
Postby DAVID THOMPSON » Thu Aug 22, 2013 4:03 pm
den wrote:thought the 125 one was the same
it is as is the one on the saxon tour
and where i live they fit nothing else that i can find
brake and clutch odd fit on all 3 of my bikes
and they seem to be cast metal so welding does not seem to safe
Postby duncmac » Fri Aug 23, 2013 1:26 pm
Bugger, that last one was not a fit either.
So time to admit defeat.
What master cylinder options are there? Ideally something from a more commons bike?
duncmac
Postby DAVID THOMPSON » Fri Aug 23, 2013 1:53 pm
here in usa the kaw bikes like klr650
kawasaki versys
the new kaw klr bikes use the same wheel calipers 2008 or 09 up use the same wheel calipers
as my 125
kymco scooters bet and win rear is same on some years
front caliper on royal enfield is same as 125 sm at least it uses the same pads
Users browsing this forum: No registered users and 309 guests
