Front Brake disc Warped!!!
Postby ptong » Thu Apr 07, 2005 10:07 am
Hi folks,
I have just found out that my front disc has warped... any ideas on what may have done it? I haven't had any accidents whatsoever... and now it sort of pulses as I use the brake. Guess I will have to buy another... I bought the bike in August of 2004... brand new... is this normal?
ptong
ptong
Postby micheleen » Thu Apr 07, 2005 11:57 am
Sound very unusual, my bike sits out in the rain all winter and apart from a bit of rust I've have no brake problems. Only other thing I can think of to warp a disc would be overheating but I'm sure you'd notice a glowing brake disc :shock:
Cheers, Mike
micheleen
Postby jbthumper » Thu Apr 07, 2005 12:05 pm
normal is not what it is.. :shock:
wheel bearings ok??because this could cause the pulse sensation...
have you checked your calipers??mountings tight??pistons working good??
is the rotor bolted on tightly??
OR
if it's really warped....you can send it for "pressing"but it won't be good as new,though...but usable.....
OR
get those wave discs for KTM exc's they look damn good!! :twisted:
Just my 2 cents...
hope it helps!!
jbthumper
Postby DAVID THOMPSON » Thu Apr 07, 2005 4:48 pm
mine was wharped also replaced it in dec 04 ok now
9016019000 front 280 mm
about $160 usd
ouch!!
Postby jayded1 » Thu Apr 07, 2005 5:30 pm
I would check the bearings or check the fastners on both rotor and caliper.
Would anyone know where to get rear break pistons? I let my pads wear down to nothing and one of mine has expanded to the point of being unuseable.
125 sx
In Bermuda
jayded1
Postby ptong » Fri Apr 08, 2005 11:03 am
thanks for the feedback.
I will check everything else, but just eyeballing it when the wheel spins shows a slight warp. I will try to get it covered under warranty. Although I have already had one warranty issue so despite my love for me bike its a bit of a p*** off.
ptong
ptong
Return to 125 cc
Users browsing this forum: No registered users and 136 guests
