Skorpion 660 Sport Electrical Issue
Postby maxknuckles » Fri Jun 21, 2013 10:47 pm
I bought this sport cup a couple weeks ago and has been running like a champ, but today out of no where it stopped working. I tried to turn the bike on and the lights wont turn on and the engine wont even make a noise when the starter button is pressed. I tested my batter and even tried to jump start it and nothing happened. My battery is completely fine also. It is not the kick stand button that is being pressed in and still wont do anything.
I think after reading it might be a blown fuse? but I cant seem to locate a fuse box anywhere. In the online owners manual it says it is under the rear seat but I see nothing. I have only tried looking with both seats off.
Any help would be great!
maxknuckles
Re: Skorpion 660 Sport Electrical Issue
Postby DAVID THOMPSON » Sat Jun 22, 2013 6:27 am
its in the mess of stuff near the battery at front of oil tank
and has a rubber cover over the fuses
check also the kill switch on right handlebar
Postby basser23 » Sat Jun 22, 2013 8:04 am
Dave is correct as usual...fuse that may have blown is the 15 amp one. There are 3 fuses in the holder,the 15 is in the middle
I think..the kill switch is marked Run and Off (I think) and is by the throttle on the right handle bar.(but,,,,even tho the kill switch may be off, the lights should come on ) ( this keyboard is really messing up))
i can't fix your keyboard
but i did edit the errors DAVE
basser23
Postby maxknuckles » Sat Jun 22, 2013 9:27 pm
Thanks guys! It was the fuse! The fuse box was hard to find because it was covered with a black rubber cover.
maxknuckles
Postby basser23 » Sun Jun 23, 2013 7:38 am
Now if it blows again,then the fun begins......I had a chafed wire in my left rear turn signal that would blow the signal fuse as soon as the signal was activated......
basser23
Postby billr » Sun Jun 23, 2013 9:33 am
basser23 wrote:Now if it blows again,then the fun begins......I had a chafed wire in my left rear turn signal that would blow the signal fuse as soon as the signal was activated......
And the dreaded diodes... :twisted:
Search the forum for info.
Welcome to the world of Skorpions.
Bill R
billr
Postby maxknuckles » Sun Jun 23, 2013 9:07 pm
so the shop I took into ( a local guy here in the bay area) beefed up the wire guage and cleaned up the wires that were every where, sporting a 30 fuse now :) :) :)
starting a new thread with pics of my bike and the fixer mods
maxknuckles
Postby DAVID THOMPSON » Sun Jun 23, 2013 9:57 pm
15 amp fuse = blown fuse next time some thing shorts out
30amp fuse = lots of smoke and maybe flame
trust me i have been at the electrical stuff for about 60 years
and MZ made that a 15 amp fuse because that was all it needed
Postby basser23 » Mon Jun 24, 2013 8:10 am
30 amp WAY too much...like Dave has stated,BURN BABY BURN!!!!! heavy wire ok,but put in a 15amp and be done till next time..could be just age,but mine is a 96 and has never(jinx coming)blown that fuse........hving said that,I have replaced all and cleaned up the wiring anyway a few years back......
basser23
Users browsing this forum: Bing [Bot] and 15 guests
