den wrote:well im having problems now adjusting the mixture and getting things right ,, well i expected to have to fettle in some way,,i'm curious ,in my previous post about what i did to the carbs i raised both needle positions to the second notch from the pointy end,,well from more research it seems that the needle on the right carb is very rich from factory and ive just made it impossibly richer and will not be able to lean it out properly,,what do you think?? should i put it back ,,think its third notch in middle as standard .
Gobsheen wrote:How did things end up Den?
Users browsing this forum: Bing [Bot] and 186 guests
