new rear pads
new rear pads
Postby handsomejackuk » Tue Apr 23, 2013 5:12 pm
had a run to M and p today to get some bits for my bikes...
anyway needed a set of rear pads for the baghira £11.00 sorted and fitted good price i thought...
Al..
handsomejackuk
Re: new rear pads
Postby iktank » Wed Apr 24, 2013 5:22 am
I was in M&P yesterday as well, picking up carb gasket set. Carbs all together all cleaned out.
Bike will be back on the road once I sorted the neutral light issue - diode must be at fault cant find what to buy to replace, googles info from David but i cant find what he descibed :( cause i dont understand probably.
Tank
iktank
Re: new rear pads
Postby DAVID THOMPSON » Wed Apr 24, 2013 8:41 am
do you have a radio shack store in the uk or a similar supplier
below will work
6A, 50V Rectifier Diodes (4-Pack)
Model: 276-1661 | Catalog #: 276-1661
Re: new rear pads
Postby iktank » Wed Apr 24, 2013 12:53 pm
David - most awesome of you, dont have radioshak but have Tandy, found what you posted.
Thanks again
Going to now proceed and butcher my wiring loom in the vcinity of the carb where the side stand swich cable and neutral stich join the loom :)
iktank
Re: new rear pads
Postby handsomejackuk » Thu Apr 25, 2013 11:07 am
we have maplins though in swansea if that is any help, and in cardiff, and in hereford, and in plymouth...and in bristol...
and in other uk places too..
handsomejackuk
Re: new rear pads
Postby handsomejackuk » Thu Apr 25, 2013 11:08 am
iktank wrote:I was in M&P yesterday as well, picking up carb gasket set. Carbs all together all cleaned out.
Tank
where is you from then Mr Iktank ?
handsomejackuk
Re: new rear pads
Postby iktank » Thu Apr 25, 2013 1:15 pm
Porthcawl, am a Swansea boy born and bred
iktank
