new baghira owner, some questions!
Re: new baghira owner, some questions!
Postby handsomejackuk » Sat Apr 06, 2013 5:38 pm
den wrote:
Skorpion wrote:This is the link to the EX North American MZ importer's carb mod's.
I ONLY cut the spring down on my Skorpion, It rev's straight round to 7200 RPM it's not asthmatic like a couple of bikes I've ridden.
http://web.archive.org/web/200212050740 ... RBMODS.HTM
Just what i been looking for , gold info mate,,now just cos someone said it though dont make it true..Has any one done this mod with sucsess,where would i get jets from ik uk
27f 34r no weave for me at 90 mph anyway...
handsomejackuk
Postby Honeybadger » Mon Apr 08, 2013 6:52 pm
Yeesh, I'm really, REALLY struggling to get the carbs off to try the cut spring modification (right side = the side without the throttle cables, correct?) How the HELL do you get them out?!
Removed the tank, I've disconnected everything but the choke cable, have loosened everything except the rail that keeps the carbs connected and the manifold boots on the cylinder head side (can't get at them with any tool on this planet earth, so the clamps from the carb to the boots is loosened completely)
I've even removed the primary bolt holding the subframe to get a little more wiggle room and they STILL won't come free. They can't possibly have been put in there with as bad of a design as it seems (who makes an enduro where fieldwork is basically impossible?) so what is the trick to getting the little bastards out?
Honeybadger
Postby Honeybadger » Mon Apr 08, 2013 9:03 pm
I finally got the damned things free, found an ancient post where someone pulled the airbox boots back in about an inch, and after removing the clamps COMPLETELY, I got enough wiggle room to slip a screwdriver into the boot and wrestle it far enough out to get the spring free, clipped off two coils and put it back in (getting the left airbox boot back on was a pain) and took it for a spin
HOLY CRAP the asthmatic problem is completely gone. the power is smooth and linear all the way to redline now!
Honeybadger
Postby handsomejackuk » Wed Apr 10, 2013 12:37 pm
grrrr i think i will do that now.... had my crabs off last year.. it helps if you lower the rear subframe this involves dismounting the zorsty pipe though... more work. but it goes back on much sweeter... just the two top rear subframe bolts is enough to allow the subframe to drop..
handsomejackuk
Postby handsomejackuk » Wed Apr 10, 2013 12:42 pm
Honeybadger wrote:I finally got the damned things free, found an ancient post where someone pulled the airbox boots back in about an inch, and after removing the clamps COMPLETELY, I got enough wiggle room to slip a screwdriver into the boot and wrestle it far enough out to get the spring free, clipped off two coils and put it back in (getting the left airbox boot back on was a pain) and took it for a spin
did you alter the synchroniser screw too as this brings the other crab in to action earlier...
handsomejackuk
Postby Honeybadger » Wed Apr 10, 2013 6:45 pm
handsomejackuk wrote:did you alter the synchroniser screw too as this brings the other crab in to action earlier...
No I didn't, should I?
Honeybadger
Previous
Users browsing this forum: No registered users and 268 guests
