Namikuz wrote: Liking the Ravens prety well so far. Chicken strips are getting smaller too!
Just put some "hot sauce" on 'em and eat 'em up...
BillR
basser23 wrote:Fried or grilled? Blue Cheese on the stems pls...
Namikuz wrote:Skorpion wrote:Those tyre sizes 120/70/17 front and 160/60/17 rear, are not recommended for a Skorpion as the wheel rim's are too narrow,
The front in particular will have pulled in the sidewall and made the tyre too pointy giving you a fast turn in and maybe nervousness at speed.
110/70/17 front is right.
The fitment is called "+1" sizing(an industry standard term) and I have personally found, over the lhe last 35-ish years riding, building, pit crew and racing motorcycles, that "+1" works very well.
angustoyou wrote:Namikuz wrote:Skorpion wrote:Those tyre sizes 120/70/17 front and 160/60/17 rear, are not recommended for a Skorpion as the wheel rim's are too narrow,
In the UK we don't have an "industry standard term" for fitting wrong size tyres. I think that's a good thing.![]()
No name tyre brands may be different, so might America, but inside Europe in general the tyre advice from the big tyre manufacturers these days is based on plenty of research and development. What they recommend tends to work. Reputations, swiftly followed by sales, are soon ruined if they don't.
Tyre manufacturers recommend a rim size that is appropriate for that particular tyre size, so that the tyre has the designed profile when in use. As Skorpion pointed out, you wont notice much width difference when fitted, as the rim is too narrow, and is pulling the tyre width in. You should notice an increase in the rolling radius because of this, which is why you will have seen a difference in your speedo reading, and is what gives that eagerness to tip in.
Of course without testing a correct size set back to back with your choice in sizes, there's no way of knowing which would be better.
WOW..... so you have nothing to ADD to the topic.... YOUR tires and what YOUR experiances have been?
Butters wrote:Pirelli Super Corsas on mine. As Bill J advised, I don't run them anywhere near MZ's recommended pressures. 27/8 psi works fine. Down side is that they are wearing fast but boy do they GRIP.
Butters wrote:Yep, the TT course is right outside my door. Yee Ha! Most of it under 3ft of snow right now.
Butters wrote:. Summer evenings give you your own personal race track( just a joke, Your Honour). No speed limits on the mountain section. Yee Ha! Most of it under 3ft of snow right now.
'Fraid not, you're not after feedback on Baghira 18" and 21" tyre performance. Skorpions points on tyre sizes were correct, i was just trying to expand on them, in your thread on tyres.
Sorry if I offended you.
