How to find 17 inch rim to fit my Baghira enduro?
Postby boschsuper » Thu Jan 24, 2013 9:23 pm
Hello I hope someone can help. I have 04 Baghira 660 with 19/21 rims and I was planning to get the super motto 17 rims so the bike can sit lower due to I am short 5'6"rider. Would a yamaha or other after market rims compatible/cross reference with hub/axle interchangeable.Where can I find or who sells it? I have lowered using dog bone links and it help a little but I need to be comfortable from stop light or a hill stop. Thanks
boschsuper
Re: How to find 17 inch rim to fit my Baghira enduro?
Postby rodge70 » Fri Jan 25, 2013 4:02 am
17" mz wheels on ebay once in a blue moon,look into a cheap wheel from an xt600/660,think it's the same hub but bearings maybe different,worth a try if cheap enough but cost of rims and re spoke will soon change that :roll:
wait till someone wants to trade 17's for 18/21.
is your bike full height :?: reduced height have shorter non adjustable forks and a shorter shock.
oh and welcome :smt006 lots of info on here
rodge70
Postby boschsuper » Fri Jan 25, 2013 9:54 am
Yes it was full height until I change the 2 shorter links. My friends made fun of me and made 5 inch wood adapters strap to my shoes when I first had the bike. Thanks for the response.
boschsuper
Postby Rhino-1 » Fri Jan 25, 2013 12:22 pm
boschsuper wrote:Hello I hope someone can help. I have 04 Baghira 660 with 19/21 rims and I was planning to get the super motto 17 rims so the bike can sit lower due to I am short 5'6"rider. Would a yamaha or other after market rims compatible/cross reference with hub/axle interchangeable.Where can I find or who sells it? I have lowered using dog bone links and it help a little but I need to be comfortable from stop light or a hill stop. Thanks
Another option (and a very viable one) is to re-lace your existing hubs with good aftermarket rims (Excel, Behr, etc.).
Good luck!
Rhino-1
Postby boschsuper » Fri Jan 25, 2013 3:32 pm
Thanks Rhino I will research those companies. Thanks again
boschsuper
Postby DAVID THOMPSON » Fri Jan 25, 2013 4:02 pm
on a re lace make sure your brake caliper will clear the new rim
a 17 may work but a 16 may not or even with the 17 may need smaller rotor
and a different caliper mount
i do not like mods they usually are a pain at the back end of a north bound mule
Dave
Postby Rhino-1 » Fri Jan 25, 2013 4:04 pm
Dave,
I hear ya', but relacing enduro rims into sumo rims is not uncommon--17" is a pretty straighforward wheel size and the enduro rotors will not be bigger than sumo rotors (usually, its very much the other way around), so he should have no issues with respect to rotor size. I believe our 17" baggy sumo rims are made by Behr (as are the KTM Duke spoked wheels)...
Rhino-1
Postby boschsuper » Fri Jan 25, 2013 5:18 pm
I was looking at a Dennis kirk catalog in the rims section. I noticed that I can probably get a front 17" Moose Rim 17X 1.40 . I would think that would make a difference by changing from 21 to 17 to lower the height and leave the rears alone since it is 18"stock and it only makes a 1" difference to 17". Good Idea?
boschsuper
Postby Rhino-1 » Fri Jan 25, 2013 7:24 pm
boschsuper wrote:I was looking at a Dennis kirk catalog in the rims section. I noticed that I can probably get a front 17" Moose Rim 17X 1.40 . I would think that would make a difference by changing from 21 to 17 to lower the height and leave the rears alone since it is 18"stock and it only makes a 1" difference to 17". Good Idea?
Good idea. I've seen that done plenty of times too. It steepens the rake a bit, but our Baggy's are fairly raked out anyway.
Here's one done (on a different bike, of course):
Rhino-1
Postby DAVID THOMPSON » Fri Jan 25, 2013 7:27 pm
shorter or longer dog bones on the rear can drop it some
but watch the wheel clearance on the frame in the rear
Postby boschsuper » Sat Jan 26, 2013 10:12 am
Would this be a crazy rear set up with 14"x 140.? I am trying to picture in my mind 17front/14 rears!
boschsuper
Postby Rhino-1 » Sat Jan 26, 2013 11:17 am
boschsuper wrote:Would this be a crazy rear set up with 14"x 140.? I am trying to picture in my mind 17front/14 rears!
Um, yes. Crazy would be one on the first words that comes to mind. But hey, it's your bike and your money, so knock yourself out... :shock:
Rhino-1
Postby edec » Sat Jan 26, 2013 1:41 pm
Boschsuper I feel your pain as I'm a little shorter than you :cry:
Good luck Brother, Ed :wink:
01 Baghira
99 Ducati SS750
edec
Postby Baggy_Al » Sat Jan 26, 2013 2:40 pm
Behr wheels are std fit on the streetmoto Baghira`s, a bit like rocking horse pooh second hand tho`.
Al.
2003 Baggy Black Panther.
Baggy_Al
Postby Rhino-1 » Sun Jan 27, 2013 9:21 pm
Baggy_Al wrote:Behr wheels are std fit on the streetmoto Baghira`s, a bit like rocking horse pooh second hand tho`.
Al.
I hear ya', but I wonder how close KaTooM Behrs would be--and they'd be in a snazzy black...
Rhino-1
Users browsing this forum: No registered users and 35 guests
