viewtopic.php?f=3&t=5728&p=29449&hilit=balance+gear#p29449
Chalks wrote:Found some interesting vintage reading incase you're thinking of holding off on the job![]()
samandkimberly wrote:Those Raptor 700 gears are pretty common on EBay for cheap, sometimes with the matching crankshaft gear; its best to replace gears in pairs, but not absolutely required. I got one, and then at the last minute decided to *not* replace it when I rebuilt my motor last fall: the old gear was in perfect condition with no signs of wear, so I decided to leave well enough alone.
Sam
Windmill wrote:Yes I'm tending that way too. Mine has 46K (kms)also, so around the same mileage, but is a very quiet engine so far as mechanical noise goes. I can't believe it's loose but it's not worth the risk. The thought of it letting go on the M1 doesn't instill much confidenceI'll pull it down once the weather improves and see.
Was yours loose when you got there Sam and any idea of mileage when you looked at it?
Thanks to Chalks for bringing this one up again. Dave, any chance of making one of these threads a sticky? It's crucial all owners of these know of the problem, if it's always at the top of the 660 section new owners may just read it![]()
Sam
den wrote:samandkimberly wrote:Those Raptor 700 gears are pretty common on EBay for cheap, sometimes with the matching crankshaft gear; its best to replace gears in pairs, but not absolutely required. I got one, and then at the last minute decided to *not* replace it when I rebuilt my motor last fall: the old gear was in perfect condition with no signs of wear, so I decided to leave well enough alone.
Sam
oh yes , i just bought a set (three gears=nut&washer) from ebay for £30 all in , 700 raptor,,wether or not it needs it , im gonna replace it , forarmed is forwarned and i hate sods law cos it allways seems to applie to me , but thats the only jobs im doing this spring , sigma carb kit and this drive gear,, should i do a youtube video??
DAVID THOMPSON wrote:i plan on doing a detailed picture book of the 660 gear change
Windmill wrote:Was yours loose when you got there Sam and any idea of mileage when you looked at it?
den wrote:So i finally got round to doing mine, upon inspection it did not need doing but as i had amassed all the parts and tools i thought why not.![]()
very straight forward job, the only things that puzzled me were , "why drain the coolant" and "why drain the oil" , the coolant pump came of as a unit and didn't need draining and with the bike tilted on the sidestand i only lost 1ltr oil from the side casing....Alas i changed the oil in the end as i bought fresh stuff and new filter.. I nearly broke the balance drive shaft , whooot,, I read here that any nut with a slit in the edges is a reverse thread,, not the case for the nut on mine ,,(balance shaft gear nut),i used my electric windy gun to free it off and ended up tightening the thing up so hard it almost rounded off the nut ,,shit my pants,,so i took some photos and made a slide show for you all,,
http://youtu.be/T8M-m0i3uWI
rode the bike to the mot station and alls well , have noticed the engine seems quieter and theres very little vibration in the handlebars,,wonder if the handlebar vibration problem is an indication the springs in the sprung drive gear for the balance and weakening and becoming sloppy thus throwing the balance out a tad,,
