Sorry if this is a "suck eggs moment " but it may help instigate a light bulb moment for the next person to attempt this ..
den wrote:I here you with the float valve pin , I know one wrong move would knock the posts off and ruin a good carb,a tip if you get brave , what i did when i do mine is,, 4 hands needed.. I use a bar with a hole in the center ( tube ) -- I held this against the opposite end and tapped the pin through with a smaller pin , The idea is that the force from the hammer blow transfers through the pin,posts and is absorbed in the tube the opposite side ,![]()
DAVID THOMPSON wrote:i have no book on carb
can some one post picture of arrow from book
as in the next week or so i will be working on mine
and this is the place i am starting
or a link to the book or picture
den wrote:I here you with the float valve pin , I know one wrong move would knock the posts off and ruin a good carb,a tip if you get brave , what i did when i do mine is,, 4 hands needed.. I use a bar with a hole in the center ( tube ) -- I held this against the opposite end and tapped the pin through with a smaller pin , The idea is that the force from the hammer blow transfers through the pin,posts and is absorbed in the tube the opposite side:
Users browsing this forum: Google [Bot] and 40 guests
