baggy 660 carb tune kit
Re: baggy 660 carb tune kit
Postby den » Thu Jan 10, 2013 5:34 pm
I here you with the float valve pin , I know one wrong move would knock the posts off and ruin a good carb,a tip if you get brave , what i did when i do mine is,, 4 hands needed.. I use a bar with a hole in the center ( tube ) -- I held this against the opposite end and tapped the pin through with a smaller pin , The idea is that the force from the hammer blow transfers through the pin,posts and is absorbed in the tube the opposite side ,
brace the end post before attempting to remove post pin
:idea:
Sorry if this is a "suck eggs moment " but it may help instigate a light bulb moment for the next person to attempt this .. :idea:
den
Postby DAVID THOMPSON » Thu Jan 10, 2013 6:03 pm
no mater how you do it this is a high risk move
Postby OLDMTNCARVER » Thu Jan 10, 2013 6:19 pm
den writes: "Sorry if this is a "suck eggs moment " but it may help instigate a light bulb moment for the next person to attempt this .."
Been there... but not with carbs yet... +1 a light bulb moment...
David responds: "no mater how you do it this is a high risk move..."
I agree just looking at it, admitting no specific experiance...
Maybe a light bulb moment...
Little heat and canned cold at the right location(s), Very carefully MIGHT help minimize undesireable results. With very minimal and careful force applied.
For your consideration,
Robert
OLDMTNCARVER
Postby duncmac » Fri Jan 11, 2013 7:58 am
I've just taken delivery of a spare carb of ebay!!
Have given the pin on the new one a few taps with a hammer, no joy, I think someones tip of applying heat to the tower with a soldering iron is the way forwards.
I'll let you know how I get on with that.
Thanks again for the replies and tips!!! :D
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby basser23 » Fri Jan 11, 2013 8:10 am
from what i remember the arrow on the pin is the INSTALL direction......try it now that you have a spare carb..
basser23
Postby basser23 » Fri Jan 11, 2013 8:24 am
i stand corrected...according to the manual,it says remove in direction of pin arrow...somehow i remember doing it the opposite
basser23
Postby duncmac » Fri Jan 11, 2013 9:03 am
No worries, I was sticking the what the manual was saying.
Not saying I didnt give it a tap on the otherside, just to see like. :wink:
duncmac
Postby den » Sat Jan 12, 2013 7:55 am
den wrote:I here you with the float valve pin , I know one wrong move would knock the posts off and ruin a good carb,a tip if you get brave , what i did when i do mine is,, 4 hands needed.. I use a bar with a hole in the center ( tube ) -- I held this against the opposite end and tapped the pin through with a smaller pin , The idea is that the force from the hammer blow transfers through the pin,posts and is absorbed in the tube the opposite side ,
:idea:
What i was trying to say in the diagram was that the opposite float assy post should be supported so as to illiminate drag from the pin and snapping the post off,,hense the hole in the tube to allow the pin to be tapped through into,
Im going to check the manual though , i also didnt relise there were arrow directions for removal , knowing me ive put it back in opposite anyways.
den
Postby DAVID THOMPSON » Sat Jan 12, 2013 12:02 pm
i have no book on carb
can some one post picture of arrow from book
as in the next week or so i will be working on mine
and this is the place i am starting
or a link to the book or picture
Postby OLDMTNCARVER » Sat Jan 12, 2013 12:26 pm
Yes sir
OLDMTNCARVER
Postby Skorpion » Sat Jan 12, 2013 12:54 pm
DAVID THOMPSON wrote:i have no book on carb
Here you are David,
I thought I had already put this up here.
http://dk-wp-uploads.s3.amazonaws.com/s ... yamaha.pdf
Skorpion
Postby OLDMTNCARVER » Sat Jan 12, 2013 1:26 pm
Thank you for posting the book.
Saved the time and cost of scanning, printing or burning a CD!
OLDMTNCARVER
Postby breakwellmz » Sat Jan 12, 2013 1:37 pm
den wrote:I here you with the float valve pin , I know one wrong move would knock the posts off and ruin a good carb,a tip if you get brave , what i did when i do mine is,, 4 hands needed.. I use a bar with a hole in the center ( tube ) -- I held this against the opposite end and tapped the pin through with a smaller pin , The idea is that the force from the hammer blow transfers through the pin,posts and is absorbed in the tube the opposite side:
IF you had the facilities,it lends itself to a home made pin pusher.
I can imagine a short`U` section of metal(But squared off)big enough to fit snugly over the outsides of both pillars(Using washers) ,with holes inline with the pin,one of them threaded.
You could push the pin out with a small screw in the threaded hole,
without the pillars being loaded.
Putting heat on it with a soldering iron has GOT to be well worth doing,whatever you try.
I`ve not actually seen the setup,but i can picture it,i THINK!
Postby OLDMTNCARVER » Sat Jan 12, 2013 3:19 pm
Just looked at the support posts that the pin goes through.
On the end of the one you might notice an arrow. FYI, I was wearing two sets of glasses.
OLDMTNCARVER
Postby duncmac » Sat Jan 12, 2013 4:41 pm
I'll find someway to wedge something between the pillars, to spread the load between the two pillars and try the heat and tapping with a small hammer.
I've got a spare carb so I might as well, I'll post up how I get on.
If anyone wants to feel jealous, have a look at how the float in the suzuki drs is set up. Sigh.....
Its like a plastic cradle that kind of clips in and is held firm by screwing the bowl on. You just tug it out....
duncmac
