Breather Hose Skorpion
Postby basser23 » Mon Dec 31, 2012 4:08 pm
Anyone change the main crank breather hose?
Seems a buggar if ya dont remove the starter...advise please, should be simple I think...heard a puffing sound and noticed cracks in the hose...1/2 in id ?(ok 13mm)?
basser23
Re: Breather Hose Skorpion
Postby RiverDrive » Tue Jan 01, 2013 11:00 am
Mine is a mess too. I've been thinking about slipping some shrink wrap, the kind used for wires, over it. Don't want to remove the starter.
01 Sport Cup Gone Sport
RiverDrive
Postby Windmill » Wed Jan 23, 2013 3:09 pm
Did mine couple of weeks ago it was cracked too - 13mm dia roughly, from crankcase back to top connection on oil tank . No problem, spring type clip at the crankcase end and not a particularly tight fit. No need to remove starter, long flat driver from rightside of bike to persuade it up a bit from the case, go round the other side and pull it up/off. I thought it looked a bit mean at first sight but actually was very easy. :D
Windmill
Postby basser23 » Wed Jan 23, 2013 6:54 pm
are you sure you're talking the breather hose? it goes from the case to the air box not oil tank!
Thanks for the info...so ya didn;t take the clamp off eh....hmm i'll give it a shot
This is the one with the spring coil inside right?
basser23
Postby Windmill » Thu Jan 24, 2013 5:37 am
The one I'm talking about is a breather but returns to the oil tank, it's about 13mm o/d but isn't the one you are meaning, sorry. Didn't I read something about the airbox one involving a coarse filter? I know the one you mean and will have a look in a min 8)
Windmill
Postby Windmill » Thu Jan 24, 2013 6:10 am
Yes, still easy. I've marked the pipes in the photo, red is the front one/to oil tank connection I was talking about, yellow is to the airbox. I actually had that one off too as the clip wasn't on correctly. Same applies although I replaced the spring clip with a jubilee clip on the front one. Hope that helps and disregard the coarse filter comment.......... :roll:
Windmill
Postby freeterri » Mon May 19, 2014 2:33 am
Hi, has anyone changed the oil breather pipe to a 'catch tank' to prevent the air filter getting dirty?
freeterri
Users browsing this forum: No registered users and 189 guests
