Ts 250/1 Cafe racer / special ?
Postby classic » Wed Nov 14, 2012 9:52 am
I've bought myself a new bike a Ts 250/1 :D
it's been modified with Honda fuel tank seat and tail piece
plus an ETZ front end and expansion chamber
has anyone seen this bike before or know who built it ?
it runs ok and the expansion pipes not too noisy
I’m hoping to do some work over the weekend and get it back on the road in the spring
Should I keep it as it is or rebuild it with the original panels ?
:D :D :D :D :D :D :D
classic
Re: Ts 250/1 Cafe racer / special ?
Postby andy288 » Wed Nov 14, 2012 11:01 am
IMO original is king every time!
:wink: :wink: :wink: :wink: :wink: :wink:
andy288
Postby arry_b » Wed Nov 14, 2012 3:42 pm
That's rather nicely done (and I like original bikes) and probably worth keeping as it is.
It'll certainly be a talking point at meetings.
arry_b
Postby therealche » Thu Nov 15, 2012 2:06 pm
I vote for keeping it as it is. Its been really nicely done. And if you want to return it to original TS250/1 you will need
Tank, with chrome side panels
Airbox, battery carrier and side panel
Rear mudguard, rear light and indicators
Seat
Silencer and downpipe
Forks, front brake front wheel
Headlamp with built in switch, alloy instrument carrier "ears" front indicators, original switch gear and levers
And thats only after a cursory look
OR you could give it a good polish up, coat of exhaust paint on the silencer, bit of hammerite here and there and you will have a good looking bike that will get people talking!
therealche
Postby radiograf » Thu Nov 15, 2012 2:29 pm
The tank and sidepanels look like they are from a Honda CB250RS from the 1980's. Be intersesting to see the mods needed to make them fit.
radiograf
Postby classic » Fri Nov 16, 2012 6:13 am
Yes the tank, seat, side panels and headlamp (still fitted with 12v bulb) are from a Honda CB250RS not sure about the front mud guard
the builder has added the small push on fittings for the side panels and a few other brackets for the tank and seat
it hadn't run for some time but i it got it going and it runs ok, it doesn't have an air box just a foam filter, i'll sort that over the winter i think
it has an etz front end, the forks don't have a pinch bolt is this normal ? :?
classic
Postby therealche » Fri Nov 16, 2012 5:24 pm
classic wrote:it has an etz front end, the forks don't have a pinch bolt is this normal ? :?
Should be pinch bolts on the bottom yoke and one on the opposite fork leg to the brake
therealche
Postby classic » Sat Nov 17, 2012 6:45 pm
Yes your right
i had a close look at the front forks and found that the front end is made up of 2 right hand fork legs :evil:
anyone have a spare left hand leg ?
The remounted choke lever is a nice touch
I think the fairing is from a Yamaha you can see that the Honda headlight is not the best fit
it seems that it was well thought out when the builder started on it but was not finished the rest is a bit of a botched job
eg: the front forks :shock:
I think that with a little work this could turn out to be nice bike :-D
Then i'll be able to ride it once i've passed my bike test :)
classic
Postby therealche » Sat Nov 17, 2012 8:13 pm
Ah I see what you mean about the forks! I'm sure someone will have a spare somewhere.
therealche
Postby DAVID THOMPSON » Sat Nov 17, 2012 10:15 pm
looks like you have one built out of extras from a very large spares bin in some ones shed
sort out the odd things and you have a good daily driver
from the look of the world wide economy there are going to be a lot of daily drivers made from a parts bin
in the future
Postby classic » Thu Dec 13, 2012 4:15 pm
DAVID THOMPSON wrote:looks like you have one built out of extras from a very large spares bin in some ones shed
in the future
yes money is tight but this will be a great bike when i get around to rebuilding it
then i'll have to get around to passing the new, new bike test :D
classic
Postby Burridge » Wed Mar 27, 2013 1:52 pm
andy288 wrote:IMO original is king every time!
Unless it's an MZ, then original is ugly everytime.
Burridge
Postby Burridge » Wed Mar 27, 2013 1:59 pm
It looks quite smart.
Although if I were you, I'd tidy up the exhaust (rub it down and spray it with XHT)
And a respray all round as that colour isn't too nice :?
And most importantly, ditch that fairing, that thing's a total botch job and ruins the whole thing.
Burridge
Postby Plaz » Wed Nov 14, 2018 8:38 am
This was my old bike. Cb250rs tank and panels, rg expansion pipe modified to fit, tzr or rg top fairing, can't remember which. Never ran properly with the exhaust on.
Plaz
Postby Puffs » Wed Nov 14, 2018 10:40 am
@Burridge: of course beauty is in the eye of the beholder.
Welcome Plaz - you mean it never ran properly with the original exhaust, or with the expansion pipe?
Users browsing this forum: Google [Bot] and 16 guests
