Mz Ets 150 1972 restauration
Postby FerreiraAveiro » Fri Sep 28, 2012 3:21 pm
Hello, among some other projects, i am restauring this motorcycle. It was apparently in good shape, but while dismantling everything comes up...here are some pics:
I have some more photos of the work done, i´ll keep posting them :wink:
FerreiraAveiro
Re: Mz Ets 150 1972 restauration
Postby FerreiraAveiro » Sat Sep 29, 2012 6:28 pm
Rewiring, etc.
I have other photos but a hard drive recently let me down and i lost most of my work.
Can anyone show or tell me how this is supposed to look? It´s been a while since i closed this engine, can´t recall if there was an outside nut and locking washer, it would be easier to just look at another one and once this engine is running i can adjust it.
FerreiraAveiro
Postby radiograf » Sun Sep 30, 2012 2:59 am
If you're wrapping a loom with tape can I suggest the self amalgamating type. I've always found that insulation tape turns nasty as the glue breaks down over time. Self amalgamating tape has no glue as such, it bonds to itself. Also known as PIB tape ( that's poly-isobutylethylene to it's friends!) a bit more expensive, but looking at the effort you are putting in worth it.
radiograf
Postby FerreiraAveiro » Sun Sep 30, 2012 5:20 am
Thanks, i´ll look for it, i was thinking about using that black one that feels like cloth to wrap the ends.
FerreiraAveiro
Postby FerreiraAveiro » Mon Oct 01, 2012 7:32 pm
Almost finished the wiring, stop light and rear turnsignals are next.
Had to make a new speedometer locker.
FerreiraAveiro
Postby FerreiraAveiro » Mon Oct 01, 2012 7:36 pm
Probably i´ll have to resize pics before uploading, they all end up chopped in one side.
FerreiraAveiro
Postby therealche » Tue Oct 02, 2012 1:44 pm
FerreiraAveiro wrote:Can anyone show or tell me how this is supposed to look? It´s been a while since i closed this engine, can´t recall if there was an outside nut and locking washer, it would be easier to just look at another one and once this engine is running i can adjust it.
There is a nut and locking washer on the other end ( clutch side) but nothing on this side
therealche
Postby FerreiraAveiro » Tue Oct 02, 2012 5:06 pm
By any chance to you have any photos of a similar engine? I really am forgetting a lot, there is no way i can remember how i left this engine on the inside, the pics i had to remember later what to finish are gone.
Thanks anyways.
FerreiraAveiro
Postby therealche » Tue Oct 02, 2012 5:44 pm
My ETS is 30 miles away but I will try to find some pictures from another site
therealche
Postby therealche » Tue Oct 02, 2012 5:55 pm
That was quicker than I thought! Heres a few pictures from iwl-motorroller-forum.de , Its from a IWL Berlin engine but they are based on the same unit
therealche
Postby therealche » Tue Oct 02, 2012 5:57 pm
therealche
Postby FerreiraAveiro » Wed Oct 03, 2012 4:06 am
Thanks a million!!!
That screwdriver´s end got me confused, thanks again. How common is it to seal the top with silicon to avoid leaks on these engines?
FerreiraAveiro
Postby therealche » Wed Oct 03, 2012 9:28 am
I usually stick some sealant over it, just to try to keep as much gearbox oil where it belongs!
therealche
Postby FerreiraAveiro » Fri Dec 13, 2013 7:32 am
Hello again everyone, i havent finished the bike, but it´s close :D
I need some help about the center stand springs:
download/file.php?mode=view&id=3512
Can anyone tell me what part number spring i need to add there, so that the stand will stay in its position once closed? It just hangs now.... this spring is new but not enough to pull it back up.
Thanks in advance.
FerreiraAveiro
Postby therealche » Fri Dec 13, 2013 5:58 pm
That`s a fine looking bike! The centre stand spring part no is 13-21.177, same as for the ES and TS. Length is approx 105mm. The problem might be this bit (A), which is not original.The spring should hook on here (B)
mz stand spring.JPG (71.45 KiB) Viewed 7863 times
As in the MZ parts book
therealche
