amahoser wrote:I guess I am a bit confused. Are you now saying that a two piston caliper side by side can be called a four piston caliper? You originally stated that the Baghira has a 4 piston caliper and now you are saying that two pistons side by side has the same swept area as a four piston caliper. So are you saying that when I look at my caliper and I see only 2 pistons side by side I should refer to it as a four piston caliper?? So there is no confusion my front caliper is a two piston side by side and my rear caliper is a single piston.
And YES I have seen pictures Baggys with 30/34s but I don't know if there was any modifications done in order to fit them. SO my question still stands.
I'm sorry if I upset you or something. I thought I did my homework but for whatever reason you don't think I did.I cannot find any info that says that a 4 piston p30/34 will fit a baghira that has 2 pistons side by side WITHOUT modification. I am almost sorry I asked on this forum. Geez, next time I should just keep my questions to myself.
Jose Soriano
Users browsing this forum: Google [Bot] and 131 guests
