Oil pump MZ ETZ
Oil pump MZ ETZ
Postby yellowduck125 » Fri May 04, 2012 3:39 pm
I am going to buy an oil pump for my ETZ 125. My question is: is there a difference between an oil pump for MZ ETZ 125 and for MZ ETZ 250? I am asking as I do not want to but wrong pump.
Regards
yellowduck125
Re: Oil pump MZ ETZ
Postby radiograf » Fri May 04, 2012 4:22 pm
Check out ebay, mz-parts-bristol has just put an oil pump on for £44.95
radiograf
Re: Oil pump MZ ETZ
Postby therealche » Fri May 04, 2012 5:03 pm
AFAIC they are different pumps for the 125/150 and the 250/301 engines.
therealche
Re: Oil pump MZ ETZ
Postby yellowduck125 » Fri May 04, 2012 5:06 pm
radiograf wrote:Check out ebay, mz-parts-bristol has just put an oil pump on for £44.95
Is it a good price?
Can I get this pump elsewhere?
yellowduck125
Re: Oil pump MZ ETZ
Postby therealche » Fri May 04, 2012 5:38 pm
Looks expensive to me..... but then Im used to buying whole bikes for that sort of money. There was a whole ETZ engine went for £9.99 last week and an oil pump for £4.99.
You could try www.themzshop.co.uk give them a ring see if they can help. I will have a look at some of my german sites and see if they have any
therealche
Re: Oil pump MZ ETZ
Postby yellowduck125 » Fri May 04, 2012 5:50 pm
therealche wrote:Looks expensive to me..... but then Im used to buying whole bikes for that sort of money. There was a whole ETZ engine went for £9.99 last week and an oil pump for £4.99.
You could try http://www.themzshop.co.uk give them a ring see if they can help. I will have a look at some of my german sites and see if they have any
Called them today and was offered MZ ETZ 125 oil pump for £57
yellowduck125
Re: Oil pump MZ ETZ
Postby yellowduck125 » Fri May 04, 2012 5:53 pm
therealche wrote:AFAIC they are different pumps for the 125/150 and the 250/301 engines.
Thank for your answer
yellowduck125
Re: Oil pump MZ ETZ
Postby therealche » Fri May 04, 2012 6:19 pm
yellowduck125 wrote:Called them today and was offered MZ ETZ 125 oil pump for £57
Yikes!!!!
therealche
Re: Oil pump MZ ETZ
Postby DAVID THOMPSON » Fri May 04, 2012 6:40 pm
yes the price of soon to be UNOBTAINUM is high and going up
try buying tubes (valves) for an old radio
or a rear fender for a 1953 bmw 500cc
Re: Oil pump MZ ETZ
Postby therealche » Sat May 05, 2012 5:28 am
Mind you a little searching can be useful! Matt you have mail!
therealche
Re: Oil pump MZ ETZ
Postby therealche » Sat May 05, 2012 5:59 am
Oh and I meant to ask, what happened to the old one?
therealche
Re: Oil pump MZ ETZ
Postby yellowduck125 » Sat May 05, 2012 6:18 am
therealche wrote:Oh and I meant to ask, what happened to the old one?
A long story behind it! the previous owner sized the engine when ran out of oil and then did not bleed the system after putting oil into the tank. He then replaced the entire engine, removed the pump- said that it rubbish and sold the bike to me.
I am a bit fed up with pre-mixing and also want to do a bit of longer distance riding with out having to curry a bottle of oil with me!
And just to let you know people do not try to fit a pump from Aprilia RS 125 -it is tempting as it fits perfectly but in RS the pump is not driven by the crankshaft shaft directey and it has to be rotated opposite way to the original one from MZ in order for it to pump oil.
yellowduck125
Users browsing this forum: Bing [Bot] and 24 guests
