Baggy-trousers wrote:No don't order those, I've just done mine. When I phoned up Marzocchi the guy there said they have just bought out some more advanced/updated seals that aren't on the website, phone them up and ask for the new 45x58x11 seals explaining they are for a bike and they will put you through to the right department. I installed mine a couple of days ago with no problems, all very simple to do. Don't hesitate to give me a shout if you are stuck with something, I'll try and get on here a bit more often!
p.s I put 10w fork oil in mine to help stop them being so squishy! (and you'll need a spanner/adjustable big enough to undo the 36mm nut on the top of your stanchions).
Baggy-trousers wrote:unless you want to drop the bike right down on it's front end on assembly i would refit stanchions off of the bike (you have to push the stanchions into the legs far enough to allow you to pull up the dampers and rescrew on the top nuts/adjusters) after filling with oil that is! Don't worry about the measurement from the top of the oil just fill each leg with 580ml of oil, Grahams motorcycles worked the amount out. I was advised to get the newer seals, they are the same price! Hope all goes well for you bud.
cat wrote:Springs out. I did mine last year. Get the manual here: http://www.teamslipstream.co.uk/pdf/Front%20Forks%20Manual.pdf
(Why didn't you get the manual first?!)
handsomejackuk wrote:cheers Bruv....
yeah i got the one side all off cleaned and sorted. just have a problem with the damper allen bolt on the bottom of the other fork... its real tight... i think i may even have rounded off the head...
have it turned upside down in my shed and filled it with penetrating fluid.. hoping i can get a good 8mm allen key bit to get it off tomorrow... most of my allen keys are worn.. so need a real good quality one and should be sorted if not will have to hammer a spline bit in there to get the bolt out...the heads are real shallow.. and the bolts are made of soft cheese.. i going to replace them with something a bit better...
Al..
Users browsing this forum: Bing [Bot] and 114 guests
