Bill Jurgenson wrote:possible problems with the harness wiring from the generator and pickup, both under that left cover.
Most probable, tho, the blue wire to the neutral switch got unhooked or damaged, very easy since ist is also routed thru a pesty little groove of that side cover.
Depending on version and harness, the neutral switch is boobytrap-wired to the ignition. Take a close look, and then there is also the boobytrap lead to the sidestand running thru there. Both of these totally unnecessary wires are often causes for problems.
breakwellmz wrote:Nice wiring diagram Dave,makes it look SO simple!
Is it really just a case of removing the side-stand switch and twisting two(?)wires together to get rid of the beast?
It`s only a matter of time before mine fails entirely due to winter road salt etc.
660_rider wrote:Thanks guys, turned out to be a broken wire!! Hidden from sight. Running now tho. With a new problem. Headers glowing red after 5 mins of idle. Never used to do this. And it hasn't even been out.
Users browsing this forum: Google [Bot] and 134 guests
