Ignition module wiring connectors
Postby MZCountryRider » Tue Jan 24, 2012 12:12 pm
Just in case anyone needs them, here's a source for the flat 2-pin and triangular 3-pin rubber connectors used on the ignition module wiring on MZ 500s and other Rotax powered bikes.
Just down from the top under New Items:
http://www.vintageconnections.com/
They don't show the flat 3-pin, but maybe that's available too.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Re: Ignition module wiring connectors
Postby comanche91 » Tue Jan 24, 2012 12:40 pm
MZCountryRider wrote:Just in case anyone needs them, here's a source for the flat 2-pin and triangular 3-pin rubber connectors used on the ignition module wiring on MZ 500s and other Rotax powered bikes.
Thanks Charlie - good info there. :smt023
Silvy is at the painter's now. Will be Ducati red w. white/black racing stripe. :-D
-Don
1-3/4 1995 Silver Stars
comanche91
Return to 500 cc
