Mastiff headlights
Mastiff headlights
Postby chris427 » Mon Nov 09, 2009 1:24 pm
Anyone changed the useless headlights on a mastiff? Mine are so bad i think if i strapped a cycle torch on the front i would see more, not good in the winter ride home from work! I was thinking of fitting a set of Bates or Dominator type pair of headlights but will i need to change the wiring and/or fit a relay? Any help would be good before i buy a set :D
chris427
Re: Mastiff headlights
Postby Mastiffred » Sun May 02, 2010 3:30 pm
No help for your problem, but I too have a Mastiff and think the lights are rubbish. Came home the other night and had to slow to a walking pace to save going off the road. Wondered if there are any uprated bulbs to try? Feel cheated as the Baggie gets an H4 which is so much better and easily improved.
It's a long road that has no turnips.
Mastiffred
Mastiffred
Postby Mastiffred » Thu May 06, 2010 3:52 pm
Further to my (not) very helpful comments, I have ordered some halogen bulbs to fit the original headlamps, if they're any better I'll let you know.
Mastiffred
Mastiffred
Postby Fil » Thu Jun 17, 2010 3:16 am
How did your halogen bulbs work out? Where did you get them from?
Luckily I don't have to use mine at night, but the bulbs don't seem to last very long due to vibration...
Fil
Postby Mastiffred » Sat Jun 26, 2010 12:42 pm
Life is never easy! The halogen bulbs were too long! The 'pip' on the end of the glass meant that you could not fit the bulb holder back onto the light, grrrrrrrrrrrrr!
I found some 40/45 upgrades, cheap but not much of an improvement on dip, a bit better on main
Mastiffred
Mastiffred
Postby afk40 » Tue Nov 22, 2011 8:35 pm
whatever you do,,,dont buy they dominator twin lights they are Rubbish
afk40
Postby chisleu » Wed Nov 23, 2011 7:39 am
Why not replace the entire housing?
chisleu
Postby afk40 » Wed Nov 23, 2011 3:53 pm
yes got ma mastiff the day... the front lights are as bright as 2 candles
afk40
Postby wookster » Sun Jan 22, 2012 5:20 pm
i fitted the acerbis cyclop to my baghira. absolutley brilliant. about the only one that is dot approved so will pass an mot. looks the dogs danglys too. check out my album for pics.
I live in my own little world! But its ok , everybody there knows me!
wookster
Postby DAVID THOMPSON » Mon Jan 23, 2012 10:30 am
i put a mz rt125 light on an old bmw and it works well
may find a lamp and bucket from a r65 LS or r45 bmw
at a used parts dealer
the bucket on /5 bmw is smaller than later /6 /7 bmw
and a r65LS lens and reflector convert it to H4 bulb
may need the power plug socket from the bmw as mz plug may be too big
in the lamp bucket
note! front head lamps are not cheap at least good ones....
Users browsing this forum: Google [Bot] and 87 guests
