dog bones
dog bones
Postby hutchy » Sun Jan 15, 2012 3:38 pm
Hi, I'm wanting to lift the backend of the baggy, do I need shorter or longer dog bones? cheers........hutchy
hutchy
Re: dog bones
Postby Bill Jurgenson » Mon Jan 16, 2012 1:34 am
I would set myself on the ground beside the bike and take good look and think...
shorter ones of course.
Re: dog bones
Postby hutchy » Mon Jan 16, 2012 4:20 pm
Thanks Bill, the font of all wisdom as usual.
I did think that i would need the shorter dog bones but thought that i would get this confirmed before fabricating some new ones.
While I have your attention Bill, can you please tell me which replacement part you use for the rubbish balancer gear, am I right in thinking it comes off a number of machines-newer xtz660 and raptor
Thanks for your help.......Hutchy
hutchy
Re: dog bones
Postby Skorpion » Mon Jan 16, 2012 4:48 pm
Hi hutchy.
Shorter ones are correct, you can buy these from GRAHAMS, they are genuine MZ parts.
Three lengths Standard 142mm? & 135mm-127mm
EDIT
Sorry the above is for the Skorpion Only.
Skorpion
Re: dog bones
Postby Old Dog » Tue Jan 17, 2012 8:25 am
Remember it will effect the sidestand, the bike will lean over a lot more, well at least my Skorpion does, but it sharpens the cornering somewhat.
All the best
Old Dog
Old Dog
Re: dog bones
Postby hutchy » Tue Jan 17, 2012 4:26 pm
thanks for the help......hutchy
hutchy
Re: dog bones
Postby basser23 » Tue Jan 17, 2012 6:32 pm
lowering the front would have the same result,,,not too much though....10mm maybe
basser23
Re: dog bones
Postby Bill Jurgenson » Wed Jan 18, 2012 5:28 am
Screen shot 2012-01-18 at 10.22.49 AM.jpg (10.05 KiB) Viewed 3228 times
the XT gear is a 1:1 replacement.
T
I prefer the Raptor gear which is thicker and does not require the heavy mild steel washer between the gear and the bearing.
I consider that washer to a part of the problem itself.
Beware, that the index on this gear does not match up in the XTZ engine.
That is not important, tho, as the keyways of both shafts face each other when the alignment is correct.
Users browsing this forum: Bing [Bot] and 49 guests
