chisleu wrote:I'm no wanna-be anything and certainly not a "stunter". I just want to be able to pop more easy wheelies in 1st with my quiet (restrictive) muffler. I also don't like the 15/45 gearing that was on the bike, and with my 6'5" 320lb body (in gear) it's not enough torque to satisfy me through 3rd and 4th. This should help with 3rd and make 4th a more bearable acceleration gear for 55-70mph.
Well. That explains it. You're twice the size of me (I'm 5'9" and half your weight). The Baghira moves me with zip
My other bike is a '99 Triumph Tiger 885. I rode it for quite a few years before getting the Baghira. But once I got the Baghira, I realize just how much easier it is to ride a bike sized to yourself. The Triumph Tiger, in many situations, was simply too much bike for me to handle (not to mention it's too heavy for me to pick up easily
chisleu wrote:I didn't count the links. This renthal o ring (~$75) chain is 120 link, but I can cut them off if there is too many. It isn't riveted (at least it isn't yet, but I don't think it is at all. I'm not breaking the seal and getting covered in that grease until I have to.)
If you have 7 more teeth on the rear sprocket, that tells me you'll need at least 10 more links, so 120 sounds about right.
chisleu wrote:Someone recommended being prepared to replace the pin on the output shaft of the tranny. I'm guessing it's a tractor pin like safety device to keep the nut from backing out during engine braking.
Yes, I wondered about that. I figure this must be a standard Yamaha part that I can get at my local shop.
