Tail Light Assembly 96 Skorp Sport
Postby basser23 » Thu Oct 01, 2009 2:09 pm
Any one have a spare,or a source?
Dont need a lense,Mounting broke where bolts go through..
Chip
basser23
Re: Tail Light Assembly 96 Skorp Sport
Postby MarkM » Mon Oct 17, 2011 3:54 pm
For a Skorpion, a Buell Blast taillight assembly from Harley works fine, mine was about $30 a couple of months ago.
I had earlier bought an LED taillight (with turn indicators) for about $35 from an ebay vendor (Ducati Monster model). Mine turned out to be complete junk. Bad molding of plastic parts, bad adhesive assembly (had fallen apart in shipping box), bad soldering of secondary circuit board, and bad customer service. There are several designs and vendors, and I'm sure some are good quality, but it will be awfully hard to tell without getting your hands on it first.
Mark
San Carlos, CA
MarkM
Postby basser23 » Tue Oct 18, 2011 9:37 am
Mark
I sorted mine with a Lucas style from Air Tech
basser23
Postby RiverDrive » Wed Oct 19, 2011 11:13 am
I think the buell matches the tour. The sport has a different tail light. Mine is practically reconstructed in epoxy. You can't tell by looking at it.
01 Sport Cup Gone Sport
RiverDrive
Postby basser23 » Wed Oct 19, 2011 3:17 pm
you are correct sir, buell one is for the tour.. sport uses one like a Ducati 750 ss i believe.
Like i siad before, the lucas style from emgo/airtech etc works a treat and looks good too..easier to hook up too..you have to use some spacers on the mount bolts extend the light
but that is no hassle,and is self evident when putting it on.I used longer bolts and nylock nuts and in 2 years it is still on original bulb,also still tight!
basser23
alternate Tail Light Assembly 96 Skorp Sport
Postby jimc » Tue Nov 08, 2011 6:52 pm
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby basser23 » Wed Nov 09, 2011 10:01 am
All good on this end too....really a good find as I said before,easy mounting and reliable..I also have some red leds mounted either side for some bling :)
Chip
basser23
Return to Wanted
