chisleu wrote: OK, I got the carb off.
There was a screen mentioned that should be cleaned but for the life of me I can't see one.
billr wrote:chisleu wrote: OK, I got the carb off.
Check this thread for how to get at the float valve filter:
Float valve pics
You'll have to scroll down a bit.
And as I said there, be very careful of the float supports...they will break off.
Bill R
harold wrote:Before you put it back together, I would either increase the size of your pilot jet, or ream it out with a welding tip cleaner. As far as your spark plug, since you got the cap off, take it out and look at it. If you are lean you should be able to see it. As you have seen how hard it is to get to the plug on this bike, a new one right now might be in order.
Then put the cap on the plug and ground it to your engine and see if it sparks. That will let you know if you were able to get the cable back into the cap right.
billr wrote:I don't remember if I had any black gunk when I pulled the carbs on the Traveller. I did spray every orifice I could identify with carb cleaner til I saw it coming out another opening...![]()
How bad is the popping? Gunshot loud or just a rumble, pop, grumble.
My Traveler is bone stock and "gently" pops on deceleration at time...I think that's part of owing a big single...
Having the air filter loose like that will definitely impact how it runs (mine worked loose once and gave me fits before I thought to check in there).
If you're not comfortable with the carb work, best to take it to a mechanic to get it sorted out.
Once it's running better, you can start doing some of the routine stuff til you're more at ease working on the bike.
Bill R
chisleu wrote:
I got up to 70mph cruising a back road and the engine started to act like it was out of gas again. I switched to reserve and tried to get back up to speed but it forced me to slow down as if I was out of gas. Eventually it let me get back up to 55 and then it did it again.
The thing that seems to make the most sense is it's running lean? Maybe I should take the carb off and clean it up? Maybe it needs a larger main jet?
You don't have normal gas tank venting if you've got that plastic bag sealing the filler, as you noted a few days ago. Let some air in the tank and you probably get normal fuel flow.
DAVID THOMPSON wrote:there is a filter in the carb behind the float needles tip and seat
sounds like its clogged
and do be careful getting the pin out that holds the float in carb
or you can break the holders for the float
do read my posts in this link
viewtopic.php?f=3&t=4705&start=15
harold wrote:Teikei jets are hard to find, unless you get one that came in a Yamaha. http://www.boats.net sells them. The part number for the largest I could find is 43f-14342-25-00 and is for a 50 pilot. When I bought mine, I found out the previous owner had already changed the stock pilot for something larger than the 50, so I reamed it out one more size with my tip cleaners- and it helped. At least on my Baghira, the pilot circuit was running very lean, with the popping as you also describe. This larger size stopped the popping, and gave more low end power.
Before you take the carbs off again, set your air screw adjustment again. Start at 6 turns and ride it, and then go 1/2 turn at a time more. I have heard of people going to 7-1/2. Of course at some point the screw is going to want to fall out, so determine where that point is first. I saw a big difference with just this adjustment.
Users browsing this forum: Bing [Bot] and 49 guests
