replacement coil help
Postby Trogolodyte » Tue Sep 13, 2011 7:53 am
Can anybody recomend a coil to replace the standard part on a 500 country (nippon denso 129700)
Have a lead (so to speak) that recomends one for a yamaha sr500/armstrong mt500 (hi level part number 713856) should work
Any help is appretiated...
Trogolodyte
Re: replacement coil help
Postby Trogolodyte » Thu Sep 15, 2011 7:53 am
ok now i am stuck, old coil (what was on thumper (500 country) when i got her...)
HT lead goes to sparky plug
spade connector is the trigger, the wire connected to it is pink & the other wire (black)
is connected to the mounting bar (thats the earth, i think)
it worked but cut out when it got hot, and after 20 mins she fires up but only runs for a short time (ten mins and cuts out again)
when left over night she will run fine again
Now I have a replacement coil now that is slightly bigger than the old one but has simmilar performance, it has the HT lead that goes to sparkyplug....
plus two connectors, one is connected to the mounting bar (am assuming it has the same purpose as the black wire/earth on the old one)
and a trigger that goes straight to the three point connector & into the loom, if all things are the same as the old coil it should work the same, well it dont...
should i... a, buy a new coil that i know will work for lots more money (about £80)
b, get a compleatly new cdi & coil from rex's speed shop (for twice as much money £160) and start again...?
Trogolodyte
Postby Trogolodyte » Thu Sep 22, 2011 2:22 am
Coils,
Have found a place on ebay (germany) that can supply NEW sr500 coils. they are the same part (Nippon denso coil), but they have a different connector instead of the three way connector they have a two point one... so some modification will be required.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0371520972
Trogolodyte
Postby Skorpion » Thu Sep 22, 2011 3:51 am
Hi Troglodyte,
Have you tried
Fred Rogers Tel 01606 593 638 9am-7pm
As I know he has some Rotax engined bike bits.
Skorpion
Postby Trogolodyte » Wed Sep 28, 2011 11:24 am
Have new coil on the way, now hunting for a replacment silencer for the 500 country...... think i would have a better chance at finding chickens teeth
Trogolodyte
Return to 500 cc
Users browsing this forum: No registered users and 63 guests
