gilerawarren-3 wrote:I need pretty much everything related to the electric start except the starter itself. I got the c/r seal with the proper spring for my sprag but everything else in there needs replaced. The sprag ollers are rounded, the snap ring that holds the sprag in is badly oval shaped as is the needle brg. The free wheeling gear is gaulded on the sprag surface and the thrust washer is wore half thru. Does anybody have any of these parts used? what would be the best source for buying them new if need be? Ron Woods or?
Trogolodyte wrote:Coils,
Have found a place on ebay (germany) that can supply NEW sr500 coils. they are the same part (Nippon denso coil), but they have a different connector instead of the three way connector they have a two point one... so some modification will be required.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0371520972
Users browsing this forum: No registered users and 86 guests
