SWITCH
SWITCH
Postby boilermaker » Thu Aug 18, 2011 3:18 pm
To all
Does anyone know the maker of the ignition switch/steering lock fitted to the Mastiff models?
George Waite
boilermaker
Re: SWITCH
Postby basser23 » Thu Aug 18, 2011 4:58 pm
of course i have one at home...I believe it begins with a Z and is also used by MotoGuzzi
thinkits the same as on a Skorpion
basser23
Re: SWITCH
Postby Norman Wade » Fri Aug 19, 2011 12:46 am
If it's the same as the Skorpion, then it's made by Zadi. A very common make on European bikes.
Norman
Norman Wade
Re: SWITCH
Postby boilermaker » Fri Aug 19, 2011 1:03 am
Gentlemen
Thank you for the info.
George Waite
boilermaker
Re: SWITCH
Postby basser23 » Fri Aug 19, 2011 9:28 am
ah yes Zadi! How could I forget :)
I had to use the actual switch assembly on my Skorp cuase you can't easily remove the lock cylinder from the upper triple tree.
(mine was raced and had a toggle switch on the molex connector to turn the ignition on and off--thank heaven the wiring was left stock!)
basser23
Users browsing this forum: No registered users and 178 guests
