air filter needed for saxon tour (and found)
Postby DAVID THOMPSON » Sat Oct 09, 2004 11:23 am
updated posting in a post at end with links to how its fixed
july 2011
hello
any one out there know of a air filter
that will fit a saxon tour with rotax 500
filter has a number on it of a620 but no brand name
i think a filter from a morris minor 1000 1963 to 1971
will fit but i cant find a listing on it in any books
any one in europe know any part numbers or subs
outside dia is 5 1/8 high is 3 and hole in middle is 2 5/16
130mmx77mm hole = 58mm
i can post a picture if needed
ar dave
follow up to air filter
Postby DAVID THOMPSON » Mon Oct 11, 2004 5:25 pm
hello
so far i have came up with some filters that may fit
the 1995 MZ saxon tour
k&n bm1298
bmw filter for r1200c the bmw chopper
and one that fits the sthil concerte saws a bit small but will do in a pinch
also a company in italy
http://www.bmcairfilters.com/
code 186/07
D1 (mm) D2 (mm) H (mm)
82 119 77
BMC REPLACEMENT FILTER - CYLINDRICAL FILTER
listed as fitting bmw r1200c the chopper bmw
this is as close as i can find so far
does anyone have a r1200c filter they can measure
more details as i dig for info
ar dave
Postby chickenman_26 » Wed Jan 26, 2005 8:26 pm
Hi Dave. I'm new to this forum. I own a '94 500 Country that uses the same air filter. I've been trying to find a suitable replacement for two years with no luck. Someone on a Euro forum reported that a Briggs & Stratton 33-2238 fits, but I can't confirm that.
If all else fails, MZ in Daytona has a huge stock of parts for the Rotax-engined bikes that they picked up when they took the brand from Jawa. Unfortunately, they won't sell direct to end user anymore, but a dealer can get it for you. About the only thing they don't have is the brake rotor (all of their stock was warped), but I talked EBC into reproducing that part last year.
CM
chickenman_26
Postby DAVID THOMPSON » Thu Jan 27, 2005 9:23 am
the filter for the r1200c looks like a fit
i have one but have not tried to see if it fits
bmw number is 13 72 1342 355
ar dave
edit for info july 2010
it fits needs adapter made from planters peanut can metal bottom
email me or pm me for details
Postby chickenman_26 » Thu Jan 27, 2005 11:55 am
DAVID THOMPSON wrote:the filter for the r1200c looks like a fit
i have one but have not tryed to see if it fits
ar dave
Well, let me know when you've actually tried it. It'll be nice to have alternatives when the NOS goes away. Until then, I believe I'll stick with OEM parts.
CM
chickenman_26
Re: air filter needed for saxon tour
Postby DAVID THOMPSON » Wed Jul 27, 2011 10:07 pm
update for this series of posts
bmw chopper filter fits its the model in the James Bond movie
take a peanut can or fritos scoops can made of paper with a metal bottom
you have the correct one if it measures 100mm across
cut lid from can and place in a lathe 3 jaw chuck to center it
cut an 88mm hole in its center..
can lip edge fits over filter
oem metal adapter drops in 88mm hole and holds filter in place
works on saxon tour should work on most mz bikes that use the a620 filter
pictures some where on mz riders
see also this link
pictures there
viewtopic.php?f=19&t=3684
Postby Louis Mair » Sat Jul 30, 2011 6:07 am
The Rotax frame is adapted from the ETZ 2-stroke. It is highly likely that they use the same filter. This is also the filter that is used on the TS 250. A Morris Minor filter does fit though it would almost certainly be easier to locate an MZ one.
I once found a K&N filter for a 1963 Chevvy (as I recall). It was a tight squeeze to get it into the TS airbox, this would not be a problem with the ETZ airbox. The holes in the K&N/Chevvy filter are too big. I cut two rings from sheet aluminium (you can't get decent peanut-tins in this sad colony).
I can find the K&N part no. but you'd eat fewer peanuts and have more time to ride your bike if you used standard parts.
Happy zedding!
Louis
Louis Mair has been different things to different people. Now I am a writer: http://www.mz301escocia.blogspot.com
Louis Mair
Postby DAVID THOMPSON » Sat Jul 30, 2011 12:25 pm
thanks for the input
you have to make it only once
wife eats the peanuts
i eat cashews and fritos
several items come in these cans here in the USA
cashews ,peanuts , fritos chips and Crisco 1lb can of shortening
to name a few
here the mz parts are very rare
as are riders that know what an MZ is...
the real story is
i had a can of fritos scoops one day at the work bench
where a bmw filter was laying to go in a friends bike
and set the can down on it by accident
later i remembered it fit when i need to make the adapter
and some times i even order them for 2 or 3 guys
with the bmw chopper bike
had one on hand and it works
now i just need to get the saxon tour out and go ride
Re: air filter needed for saxon tour (and found)
Postby comanche91 » Sun Jul 31, 2011 11:27 am
K&N BM-1298 filter with brass centre hole cover. Made from an old brass candle holder. Works well.
-Don
1-3/4 1995 Silver Stars
comanche91
Postby daneng » Tue Jul 08, 2014 7:50 am
daneng
Postby DAVID THOMPSON » Tue Jul 08, 2014 10:46 am
22-33.018
Luftfilter A-130/82
Micro filter A-130/82
22-33.018 Luftfilter
is the number your looking for
i just buy one for the bmw chopper r1200c and use an adapter i made
the ori filter is expensive after shipping cost and not found in the usa except the k and in unit
Users browsing this forum: No registered users and 188 guests
