Why 3 fuses instead of 4?
Postby harold » Sun Jul 24, 2011 1:54 pm
Having just got this bike, 2002 Baghira a couple of weeks ago, this forum has been tremendously helpful. I noticed when I bought the bike, that the fuse block only had 3 fuses, even though on the side you can see where it lists 4 fuses, as does the parts diagrams I have seen. The fuse block looks untouched, but the previous owner said when they bought the bike several wires were disconnected in this area, so the fuse block may not be stock. It wouldn't bother be so much except the neutral light doesn't work. I have checked the bulb and it is OK, so I am wondering if there is another wire that should go to the 4th fuse that isn't, and that's why my neutral light doesn't work. I appear to be missing my 15 amp circuit.
Cam someone tell me:
1. What fuse the neutral light runs off of. I found out the hard way that the 3 amp fuse in the middle does the turn indicators.
2. Should the heat light come on with the key, like most warning lights, to let you know the bulb is good? I have checked it, and the bulb works, but it never comes on. The bike doesn't run hot, but it would be nice to know that the warning light worked if it ever did overheat.
harold
Re: Why 3 fuses instead of 4?
Postby slammer449 » Wed Jul 27, 2011 7:13 pm
Looking at my baghira wiring diagram i have four fuses. 3amp,7amp, 15 amp and 20amp fuse. One of the fuses the 7amp supplies power directly to the thermo switch which controls the engine fans and also the warning light. Coming off the fuse block the wire is listed as sw 0.75.. Don't know what color sw is... Sorry I don,t know the color of the wire right now but will take a look at it sat morning and get back to you... My fans come on after idleing in the garage about 5 minutes on a 90 degree day... temp light has never come on ...I should check the bulb probably just to be safe
02 baghira- 74 rd350 piped, ported and podded. .a jetting nightmare
slammer449
Postby slammer449 » Wed Jul 27, 2011 7:32 pm
wiring diagram http://andyashton.com/mz/MZWiring.pdf Don't know how to put in links yet
slammer449
Postby MSW » Wed Jul 27, 2011 9:43 pm
All the wire colors are in German. That threw me a little too.
sw = Black (schwarz)
ws = White (weiss)
rt = Red (rot)
br = Brown (brun)
gr = Green (grun)
ge = Yellow (gelb)
bl = Blue (blau)
Not too difficult to figure out, but I would have had to get yellow by a process of elimination.
MSW
2005 Black Panther
MSW
Postby DAVID THOMPSON » Wed Jul 27, 2011 10:56 pm
in the electrical drawing
item 31 a diode also with markings 31a and 31b
its part of the interlock safety relay item 30 if its open or shorted
it can cause all sorts of weird things to happen
i do not know where it is in the harness
some one else may know
its to left and up from the battery on the drawing
like about 10am on a clock
Postby Bill Jurgenson » Thu Jul 28, 2011 11:58 am
finding the diode in the harness is about like finding water with a divining rod. Anybody's guess where it might be.
Can't speak for the Baggi but the Skorpion also has the 3 fuse holder. The fuse for the fans and thermo switches and is separate, in line.
Postby harold » Thu Jul 28, 2011 5:12 pm
Thanks for the replies. With the wiring diagram I will try to trace some things.
But can someone tell me, does your heat light come on with the key, like a normal warning light? And, even in FL, my fans so far have never come on that I have seen. The bike also has never acted like it was over heating. After a 15 minute ride at 95 degrees, when I turned it off, I could put my hand on the radiator cap. BY the way, when you try to next put your hand on a radiator hose, with bifoculs and a semi dark garage, your black exhaust pipe looks a lot like a hose. Until you touch it of course.
I would try the 5 minute idle thing, but after reading the thread about thumpers and idling, I won't worry about it until or unless it ever gets hot. And screw the hose test the next time.
harold
Postby billr » Thu Jul 28, 2011 5:56 pm
harold wrote: Thanks for the replies. With the wiring diagram I will try to trace some things.
Nope, doesn't come on to test function. It's really just an "Eye Dee 10 Tee" light. :D
harold wrote:And, even in FL, my fans so far have never come on that I have seen. The bike also has never acted like it was over heating.
The previous owner of mine had wired a switch into the fans "because they stopped coming on". I finally figured that out (bad sensor/switch) and they work fine, at present.
I did have the light come on a few weeks ago (poking around the parking lot), blown fuse...replaced that and all was well.
Right now, it's hitting the high 90's here in Nashville. The fans will kick on in really slow traffic and occasionally when I get home and park it (30 minute suburban commute).
You can use a jumper wire on the switch to check that the fans will at least come on. And I'd check that bulb someway.
harold wrote:And screw the hose test the next time.
Reminds me of the old blacksmith/horseshoe joke..."I told you that thing was hot"..."Nope, just don't take me long to look at a horseshoe... :D
Good luck,
Bill R
billr
Postby DAVID THOMPSON » Thu Jul 28, 2011 10:27 pm
i jumper my fans at the thermo switch a couple times a year and let them run for a bit
so there not stuck when they do need to come on
hot here but not getting any fans running
but have not been getting stuck in traffic
every one is staying home hugging there air conditioner
Postby harold » Fri Jul 29, 2011 7:19 am
Thanks guys. It is nice to know about the heat warning light. Since the wiring on this bike has been messed with, I didn't know what I should expect. I will jumper the fans to make sure they work. The neutral light is something that I can do without, but I am hoping to find a wire that they just didn't connect right. These diagrams will help. The PO disconnected the side stand switch, and just twisted the wires together. That is where I think I'll start looking.
harold
Postby DAVID THOMPSON » Fri Jul 29, 2011 11:14 am
i do not like the bypassed side stand switch
but if you do... do solder it so it does not leave you setting
Postby billr » Fri Jul 29, 2011 11:27 am
DAVID THOMPSON wrote:just twisted the wires together
I have to agree. As much of a headache as it can be, I've managed to ride off with the side stand down on a couple of other bikes... :oops:
Not on the Skorp :D
billr
Postby DAVID THOMPSON » Fri Jul 29, 2011 3:35 pm
the above 2 post are
saying
it hurts when you fall off
even at slow speed
and sticking a side stand in the ground at any kind of speed
will make you fall down just like they do on the crash and burn TV shows
Postby Skorpion660 » Sat Jul 30, 2011 3:58 pm
Not on the Skorp :D
Well, after reading the wise words of billr I reconnected my sidestand switch today whilst prepping my bike for its MOT next week. I'd disconnected it a while ago and had fitted a jumper so I refitted it and put a jumper back in just in case of any future problems.
Terry
Skorpion660
Users browsing this forum: No registered users and 205 guests
