Tigerboy wrote:Over 38,000 km on the original chain and sprockets, the time has come to replace them.
I'm happy with how my Baghira runs, so I want to go with what's already there. My bike came with a 15/43 setup. As for the chain, I have no idea and that's where I need help.
This is what I've found so far.
MZ Baghira is not to be found on Bike Bandit, so thanks for letting me know the Yamaha XV250 is the equivalent. I found the JT Sprockets 15/43 that should fit.
Next is the chain. First, I need to count the links, but it sounds like for the motard setup, it's probably 110. But I don't know how to proceed from there. Shouold I go with X ring (more expensive) or O ring? According to Bike Bandit, the XV250 would take a 520 chain (to go with the JT sprockets) I will want a chain with a master link so that I don't have to remove the swingarm to install it.
chisleu wrote:I just hope this 120 works on mine! My sprockets are inc from germany (ordered a 15/50) so I'll let you know how this does when it arrives.
Tigerboy wrote:chisleu wrote:I just hope this 120 works on mine! My sprockets are inc from germany (ordered a 15/50) so I'll let you know how this does when it arrives.
You must ride in aggressive off-road terrain or you're a wannabe stunter if you're running 15/50. But I am curious how it works out.
I counted the chain links. I counted 55 but I guess each link counts as two, so therefore 110. I went with the Moose Racing 520 O-Ring chain. Anything more than that is a waste of money IMHO. This isn't a sportbike that will do 165 mph.
Now to replace chain/sprockets I hope there aren't any other parts I overlooked.
I also wore my rear tire down to the cords, so I ordered Pirelli Scorpion Trail, replacing a Scorpion Sync. The Scorpion Sync lasted about 8,000 miles so it was a good tire.
