Right hand light switch
Postby Fluffy_Dog_1018 » Sun Dec 05, 2010 8:40 am
Hi, thinking of using light switch on right handle bar to control some auxiliary lighting on my bike. As mine is a US bike it appears that this switch is disabled i.e. headlight is always on. Anyone have experience using this switch to do what I am thinking about? I'd rather use it than add a switch to the console. Thanks.
Somthin ain't right.
1982 Yamaha Maxim SOLD
2001 Suzuki SV650 SOLD
2001 Kawasaki Concours SOLD
1983 Honda CB650SC SOLD
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Re: Right hand light switch
Postby Norman Wade » Sun Dec 05, 2010 11:26 am
Here in the UK we are able to switch the lights off and on with this switch. I've copied the connections from the wiring diagram:
Sorry it's not very clear, but hopefully clear enough to understand.
The light switch (5) obtains switched +12V from pin 9 red/black wire (rt/sw). This is the same supply as the brake switch (9 on the diagram).
When the switch is in the 'P' position, power is connected to pin 1 black/white wire (sw/ws), and when in 'H' position it is also connected to pin 3 white wire (ws).
Hope this helps,
Norman
Norman Wade
Postby DAVID THOMPSON » Sun Dec 05, 2010 11:45 am
when you decide where to hook for the switched power
do use a relay to power the added items.
drawing very much power threw the switch is not
a good idea
Postby Fluffy_Dog_1018 » Sun Dec 05, 2010 2:19 pm
Hi Norman, thanks for the diagram it will get me started.
Dave, yes I plan to use the switch only to control a relay I have wired (via fuse) to the battery.
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby spaceaged » Wed Dec 08, 2010 2:15 am
I was thinking about doing the same thing with my '02 Tour. I haven't checked the wiring continuity from the switch yet. The switch throw feels very loose on mine. It slides back and forth without and real positive snapping into place. I'm not sure it opens or closes any contacts. I bought some LED lights and a handle bar mount switch from Trail-Tech. I'd rather use the stock switch if I can.
spaceaged
Postby Berniecal » Wed Dec 08, 2010 11:35 am
The switch is a real switch with wires terminating in the headlamp cowl, but as Dave has said, the switch should only be used for very low current (maybe 1A) and/or to control a relay.
2001 Skorpion Tour. Of about 50 bikes I have owned, this is the one I have kept the longest.
Berniecal
Users browsing this forum: Bing [Bot] and 6 guests
