Gear change - especially first gear
Postby RChandler01 » Mon May 17, 2010 4:13 am
Hi to all,
Slowly but surely my bike is becoming closer for use on longer rides, i.e. my confidence is increasing! However I now need to sort out the gear change / selection.
First gear is always very notchy and quite often becomes difficult to select as does neutral. With the clutch pulled in it doesnt stall or drag but the gears are difficult to find, this doesnt help with my nerves when at the front of a queue of traffic...I have recently had the oil changed.
Any ideas?
Cheers
Richard
RChandler01
Re: Gear change - especially first gear
Postby djsbriscoe » Mon May 17, 2010 6:00 am
What bike are you riding?
Does this happen when the engine is hot?
Have you checked the clutch adjustment?
David.
Electronics tech by trade.
djsbriscoe
Postby RChandler01 » Mon May 17, 2010 7:12 am
Its the 125SM and yes it does happen once the bike is up to temp..
Clutch adjustment on the clutch plates for clutch lever?
Cheers
Richard
RChandler01
Postby djsbriscoe » Mon May 17, 2010 7:35 am
If it's a fairly new bike it might take a while to loosen up. For instance I very rarely use 6th gear (live in central London and commute in slow traffic) and that gear is a bit stiff to get into. I've also found that if the gear lever has any pressure on it when you are not changing gear it can sometimes cause missed gears.
Also have you checked the chain tension this might be too tight and could affect the gear change.
David.
djsbriscoe
Postby RChandler01 » Mon May 17, 2010 7:53 am
Thanks David. My bike isn't too new, it is a 2002 and it has done 14,000 KMs.
I am going to have a fiddle with the clutch adjustment for now and share updates and hopefully progress.
Cheers
Richard
RChandler01
Return to 125 cc
Users browsing this forum: Bing [Bot] and 197 guests
