I want a Wheelie Monster !
Postby Daris Pakar » Wed Nov 10, 2004 10:23 am
I don't care about Fast
I don't care about MPG
I want Wheelies on demand in 1st and 2nd !
Any advice as to spocket choice and clutch tuning ?
2002 MZ Street/Moto Low
1989 Honda TA
1990 BMW PD
2002 MZ SM
Daris Pakar
Postby gedge » Wed Nov 10, 2004 4:42 pm
I have a Baggy SM and have gone down 1 tooth at the front. it now wheelies quite easily in first ,but I still struggle to get her up in second.. I reckon you would have to go up to a 45 rear to make it any easier :D
gedge
Postby phlat65 » Wed Nov 10, 2004 9:28 pm
I have stock gearing in my baggy, and can carry very nice 2nd gear wheelies, recomend starting with very low revs, 2nd gear, prob 15-18 mph, quick clutch blip, and it is skyward!!
Postby gedge » Thu Nov 11, 2004 5:14 am
It must be either my size,13 stone, or just that I dont have the knack... wheelies fine in first ( within my limited skills in this department) , but can barely get the wheel to leave terra firma in second ( unless you throw in a hump backed bridge in which case it can wheely in third :-D ( nearly had me off the back last time at about 55mph :oops: )
gedge
Postby Dezmo » Thu Nov 11, 2004 11:32 am
install this sprocket:
if that doesnt work, have my mate there ride pillion
youll be doing wheelies in no time
Hella Yella, coming ta getcha!
Dezmo
Postby keithcross » Thu Nov 11, 2004 2:59 pm
Gedge
Seen you pull some neat 1st gear wheelies. 13 stone though, are you sure?
Postby hulagun » Thu Nov 11, 2004 3:01 pm
No matter the gearing, the real problem seems to me is that the rev limiter snuffs the spark just as the front wheel gets 6" off ground.
Unless someone can make a case against it, I'm planning on getting a higher rpm limiter from Bernd at Tunebike.de (Germany).
I'm open to arguments against it. Phlat?
1978 Ducati 900SS cafe racer
1969 Triumph Bonneville 650
1966 Honda CB160 F160 racer
hulagun
Postby keithcross » Thu Nov 11, 2004 3:04 pm
I dont know if the Yamaha TDM 850 is sold state side, but the ignition box fits and works. This unit does not have a built in rev limiter (or if it does it operates at a lot higher rpm). If this bike is sold state side, try the motor cycle dismantlers.
Postby hulagun » Thu Nov 11, 2004 9:38 pm
keithcross wrote:I dont know if the Yamaha TDM 850 is sold state side, but the ignition box fits and works. This unit does not have a built in rev limiter (or if it does it operates at a lot higher rpm). If this bike is sold state side, try the motor cycle dismantlers.
Really!!! Awesome. There are some of those around. Maybe I can find one cheap to use temporarily. I dont want to eliminate my rev limit tho, just move it upward some.
Ivan
hulagun
Postby gedge » Fri Nov 12, 2004 4:32 am
keithcross wrote:Gedge
Last time I checked it was 13.3.. may have been at the pies a bit over the past few weeks though :shock:
gedge
Postby phlat65 » Fri Nov 12, 2004 10:22 am
more revs are not going to help you out. use the tourque of the motor at low revs to get the front up, try filming your technuique, biggest mistake most people make when attempting wheelies is to lean FORWARD!!!
try practicing on a bmx bike, or a small 4-stroke play bike 1st to get the feel of the ballance point. the higher you get the front wheel, the less power it takes to keep it there.
bumping up the rev limiter will not do much without other mods to match the increase in air flow.
Postby hulagun » Fri Nov 12, 2004 5:12 pm
thanks for the tips, phlat. I must be doing something wrong, although I had no problem standing my Rotax, SV or Falco on their tails in first. Of course they have better power/weight ratios.
Like I said, I can hoist the front on the throttle but in first it donks the rev limiter before getting high enough to balance. Maybe I need to practice using 2nd gear and the clutch...
hulagun
Postby gedge » Sat Nov 13, 2004 11:12 am
dunno if it was just following your advice or whethr the new brisk spark plug that made a difference , but today I manged to get it to wheely in second.... Not very far yet, but now I know itwill get off the ground, I am much happier.
I also manged to get from first to second with the wheel up ,and I reckon with practice that this will be the way to go :D All I need is for the nice weather to hold for a few more days so I can practice :-)
gedge
Postby Daris Pakar » Thu Dec 02, 2004 5:39 am
BUMP
1989 Honda TA
1990 BMW PD
2002 MZ SM
Daris Pakar
Postby Jungley Barry » Sat Dec 11, 2004 2:59 pm
My Mastiff wheelies off the throttle in first at about 12mph - ride it up to that speed and then spank the throttle open as if you were revving up at traffic lights next to a dick'ead car driver and up it comes.
Just keep practising that and you'll soon end up keeping the wheel in the air for longer and longer. When you get to a point where you start to run out of gear, click it into second and away ... :wink:
I'm too unimaginative to think of anything witty ...
Jungley Barry
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
