Washing machines and MZs....
Postby bikerbabe » Fri Dec 10, 2004 6:32 pm
The rear wheel bearings on my '94 Skorpion Tour are on the way out. I have got the part numbers from MZ (The part number for the wheel bearings is 90-13.177 and the sprocket carrier bearings is 90-13.188 There are two of each fitted to the rear wheel assy.) but a friend reckons they might be interchangeable with washing machine bearings (which he has in stock).
Would this be the case d'you think?
:roll:
Can't think of one.
bikerbabe
Postby phlat65 » Fri Dec 10, 2004 9:56 pm
very possible, there are a few bearings that are a very common size...
Postby DAVID THOMPSON » Fri Dec 10, 2004 10:21 pm
hello
the parts book has a description after the number
like on my saxon tour
6 93-94.236 Rillenkugellager DIN625-6302-2 Z
the din number tells a bearing store what it is but also take the original
for them to measure
for mine skf 6302 -2z
find din number number in your parts book and i may be able to tell you what brand and number but they will be of a better grade than in a washing machine
ar dave
Postby bikerbabe » Sat Dec 11, 2004 4:19 am
I don't have a parts book.... :(
Can't think of one.
bikerbabe
Postby oldbeginner » Mon Dec 13, 2004 9:02 pm
I just had the wheel bearings changed on my Skorpion Sport race bike. I'll try and post the bearing numbers shortly.
oldbeginner
