Oil Leak
Oil Leak
Postby sapperk9 » Fri Mar 19, 2010 3:30 am
I have an oil leak, only when running, right under the starter motor, its from the crankcase split, as far as I can tell. Any offers of solutions other than a complete motor tear down and reseal of crankcase halves? :cry:
Cheers...
"In questions of science the authority of a thousand is not worth the humble reasoning of a single individual." - Galileo Galilei
sapperk9
Re: Oil Leak
Postby Bill Jurgenson » Fri Mar 19, 2010 4:16 am
couple of possibilities there but the joint of the crankcase is not at all probable.
1) crankcase vent hose, that black plastic hose about 1/2"Ø cracked or just very loose;
2) oiltank vent hose, in front of the above and about 3/8" Ø same problems;
3) Oil return line loose or its O-ring bad or both, it is under the starter towards the back, and is held by two M inbus screws.
4) to the right of the first item, there is a large black plastic plug in the crankcase. This has been known to crack or even to blow out.
Re: Oil Leak
Postby Anders » Fri Mar 19, 2010 10:50 am
While speaking of leaking hoses, MuZ did not use the best quality avaliable to say the least.
I highly recommend to check all hoses and especially those in contact with oil for cracks and replace if needed.
I had to replace most breather and oil lines when my -95 Skorpion was no more than 5 years old, first clue was a serious oil spill on my rear tire from the return line to the oil tank, could have ended in tears.
In my garage:
Honda VTR 1000F -00
Orion-29 125cc, Midsize
49cc Bike engine kit toy
Yamaha SRX-6 -86
MuZ Skorpion 660 -95
Polaris 6x6 Big Boss
Nordic SRX/MuZ/SZR forum
Anders
Re: Oil Leak
Postby sapperk9 » Sat Mar 20, 2010 7:37 am
Thanks gents, I'll scrutinise the machine next week, the starter motor is off but I'm off to a birthday party for my Guzzi dealer on Sunday.
http://www.thunderbikes.com.au/
Cheers
Jim
sapperk9
Users browsing this forum: Google [Bot] and 95 guests
